I'm trying to make a decision whether or not to buy a brake lathe. Since brake rotors are not very pricey do you think is better to just sell complete brake job pads and rotors instead of turning them? One of the independent shops I used to work for did not have a brake lathe and it worked out pretty good for him. Does anyone else use this approach, or is a brake lathe needed?
I bought a used brake lathe on craigslist when I opened up. Can't remember exactly what I paid for it, but I think it was around $2000, maybe $1800. Came with the bench/table, adapters and cones. Cleaned it up with some WD-40, spray painted the the bench, and replaced a boot.
I don't know if it was worth it, but it's hard to measure. Selling rotors on every brake job is gonna add ~80-100 I would guess. That could cause some customers to go somewhere else. Not that you want to be the cheapest guy in town, but people do pay attention to price regardless.
Well at the shop that I worked for he would charge $200 for the brake job that included brake pads and rotors. I guess he was able to make it with a little bit of profit after paying tech. I might just look into the brake lathe.
We have a on car lathe and a bench lathe. We are on our second on car pro cut. I do not think we could make it with out the on car lathe. Saves a lot of time and the finish is great. I cannot count the times we have gotten warped new rotors out of the box. Plus the expense for rotors for every vehicle does not make sense to me. I do not think I have seen a brake job for $200 even with out replacing the brake rotors for a very long time.
I guess I just do not experience this. We can turn the brake rotors with no issues. The procut is a great product.
We use our brake lathe a good bit. Some of the medium truck rotors are expensive and hard to get. Of course, the odd ball "high end" car we see gets new rotors with each brake job. I've also noticed most newer GM cars are right at discard after the factory pads wear out. We measure each rotor/drum to make sure we can resurface them.
We don't own a brake lathe and we sell brake rotors with almost every job we do. I just feel if we are doing a proper repair this customer shouldn't be having a brake related issue for approx. 50k miles or more. (well worth the money spent) I also don't use cheap brake parts.....
Edited by ATSAutomotive
I have thought about one myself for several years but the time lost waiting for the rotors to turn verses just replacing them has kept me from buying a lathe. By the time you add the labor to cover the time spent to turn the rotors, its almost even to just replace the rotors with new ones and you don't normally have to worry about if you will have a vibration when you are done.
For those who have an on car brake lathe, how much labor do you charge to cut a rotor and how much average time is spent? I can see the value in adding a few bucks to a job where the customer doesn't want new rotors and the old ones are salvageable.
Mine isn't an on car lathe, it's a bench lathe. I charge $200 for a brake job with machining rotors. If I have to replace the rotors, it is at least an extra $100, depending on the vehicle. Keep in mind, I'm using dealer parts 99% of the time and that's what my customers want.
If they go for a cheaper aftermarket option, the price reflects it, but not much.
Edited by mmotley
Joe nailed it. The metals anymore warp rather quickly due to there cheap alloys and the fact that they are not as thick. I wouldn't waste money on a lathe.
I'm really surprised at how many people don't have lathes! It's an expensive piece of equipment, no doubt. Car count definitely plays a role in it and also where you get your parts from. Cool to see all this feedback from everyone.
We only have a ProCut on car lathe at the shop. No bench lathe. Best investment yet!! We charge an hour labor per axle to cut. We actually try to sell cutting new rotors to match the vehicle. There are many advantages to having an on car lathe. Number one being no combacks! You can true it up nice on a bench but if the vehicles stacked tolerances are high then it will eventually come back with a pulsation. +1 for on car!!!
Hey Dustin, wondering if you could give some insight on a few things.
What is your hourly rate? Trying to get an idea of what I can charge for a cut rotor. Do you charge more for cross drilled/slotted rotors?
How long does it take to perform the service per side?
Have you had an difficulties or problems initializing the system and getting the job done? How often are there other issues that cause problems such as wheel bearings?
Our hourly rate is 74.95. I have yet to get any drilled or slotted rotors in but I would probably charge the same.
If you are used to the machine you can setup and cut each side in about 15-20minutes per/side. Also the Procut is designed to be a single pass so that also saves time.
I usually like to put a dial gauge on the rotor before and after to see the difference in the runout. But all the turning in the world does not work if you have worn components so an initial check is made to insure that the car is up to par.
As for difficulties that I have encountered.. I can't say that I have. You pull the caliper and leave the brackets on then set up the machine. Sometimes I spend a little time finding the correct adapter but that is solved with procut's website. They added a nice adapter search so that clears that issue up nicely. If you have questions or want to chat give me a call.
Thanks Dustin will do!
I've been looking at the Pro Cut a bit more closely, I had a customer recently with a stoptech big brake kit. Has some weird wear on his rotors due to him not driving the car very often. Those rotors are probably in the $400+ range. Got me thinking about an On Car Lathe. I have always debated on how to set apart our brake service from the rest of the competition. We are a German Specialty shop so most of the services we provide are catered toward those car makes and customer generally know they can't get the same service elsewhere even at the dealer sometimes. Brakes on the other hand I've always debated on how to sell since a lot of franchise shops offer crazy deals as well as other chain stores. I know for a fact no one in my area does Rotor Matching and if what is advertised is true, if I can put of a better job and ensure no comebacks and 100% satisfaction I am very much interested.
I agree, Procut was really good at coming out and training everyone in the shop on the machine. They provide you with TONS of sales material for customers and also nice counter displays. Most importantly they tech you how to sell the service!! They are constantly sending me more kits with additional sales material. We have a lot of equipment here but no company that we deal with put that much effort into helping you make money with the machine they sold you. Usually when they make the sale then they throw you to the wolfs and walk away! (Kinda reminds me of the first day of wrenching way back then)
I have found if you actually take the 2 extra minutes to actively (through using material and displays) show the customers the benefit of the service we make the sale.
If you want, call me and I will give you the number to someone at procut to talk to. I got a really good deal because I bought one that they had that was a demo unit for a dealer they were trying to sell to. Only had about 10 cuts on it and saved us big $ off the price.
My suggestion is do not try and compete with franchise shops. Or the other shops, or the dealers for the matter. You can put a better job out then the others you mention here. If you do that then the competitions is over with. Your job then is to make sure your customers you have now and the future one know it. From there you will be leading and they will be left scratching their heads to try and beat you.
When we first opened we had two lathes. One was set up for drums and one for rotors. We only have one now as that is enough. At one time I wanted to buy a Procut on the car lathe now I never will. I don't think I can justify the cost or the time involved in using it.
Do you replace rotors more than machining them?
As you can see I am not xrac. My take is you are to "true" all rotors to do a thorough and proper brake service. This goes for re using or replacing them.
Care to elaborate as this doesn't make sense to me?
I would be glad to! Any particular part of the comment you wish me to focus on?
I have worked at Subaru and now Hyundai. We turn rotors if we can, which is more often than not. For warranty work we have to use the on-car, if not we can use either-or. We get a lot of brake jobs. Even though our labor rate is high at 105.00, our brake jobs costs are generally lower than the independent shops who (in my opinion, foolishly) only go the new rotors route. We have flat pricing for our brands. 249.95 includes new OEM pads and hardware, turned rotors, serviced calipers for the rear, 299.95 for the same in the front. If it is an off brand pricing varies, but it usually all falls between 199.95 and 299.95. Our brake jobs with turned rotors still take an hour or less for any of our techs to do, I usually get them out in 50 minutes time. Our comeback rate on them is low as well.
We charge 0.5 for the turning of rotors per axle. So if they need new rotors it now becomes 199.95 + cost of rotors for the rear, or 249.95 + cost of rotors for the front. This is OEM of course. The average cost of rotors is around 69.95, so we are talking about 339.95 rear or 389.95 front. It's a substantial savings in the customer's eyes. Average brake job with rotors at an indy shop around here is about 299.95 to 399.95, and I couldn't tell you in good conscious what brand parts that includes. Most of them refuse to turn rotors, which helps us stay busy with gravy brakes.
Our techs get paid 2.0 with a resurface or 1.5 with replacements.
Your numbers really don't work and being a tech you really have no idea about what satisfactions are and your comback numbers. Most people don't complain, they just don't come back so in reality you don't know the failure rate of the rotors. Two-hundred and fifty bucks for turned rotors and front pads is certainly not any kind of a deal in any town I've ever seen.
Dealerships and Independents are from 2 totally different mindsets. As an independent I can and do refuse work or installing parts I do not believe in when working on my customers vehicles. I'm there to provide a needed service to my customers vehicles and I will only do repairs that will do that. A dealer doesn't turn any work down that a nickle can be made from.
Explain what you mean by "Your numbers really don't work" please...
Before you go out and say " being a tech you really have no idea about what satisfactions are and your comback numbers" I would give ADealerTech a little more credit and ask him a question about it before just shooting him down. He may know more then you give credit for. Have you been in his shoes? See instead of me just saying you're not in his shoes I ask have you been in his shoes.
$250 bucks for a good job is a deal! $125.00 for a half ass job is not and it's half the price. :)
On certain things they are two different mind sets. With customer pay jobs they are one in the same.
Look forward to your reply.
Since you haven't provided anything relevant other than assumptions of what I do and don't know about what goes on in the place of business I work at. I will just say this:
I hold an automotive service degree, which I obtained after I was laid off from my previous job, which was an investment advisor for Bank of America. I also hold a finance degree, which was required to hold the job I had. So, I have a little idea of how business works, and by a little, since I helped advise owners of companies multiple 100s of times larger than yours, I mean a lot.
I also am currently working on my business management degree, so that when I do finally pull the trigger on my own shop, I will have an excellent shot at staying solvent and viable. Notice how I said shop? That is because I already am an actual business owner, I am registered with the state of RI and carry a personal liability rider and report all my side work as income to keep legitimate and build a client base for my future endeavors. So I do know a little something about running a business of my own as well.
Furthermore, I happen to be the one living in Rhode Island, seeing the prices of dealers and independents in my specific area and it qualifies me a whole lot more than you to know what is a deal for the area.
Lastly, anyone can open a business, it does not mean they have good business sense, or any sort of authority over knowledge on how to run one.
Your contempt for techs tells me a lot about you.
ADealerTech, Thanks a lot for your input. Its great to read constructive information from the other side of the coin. Phynny, I think you should take it easy on the techs on the board. The ones like ADealerTech are only trying to help. Lets all get a long!
There are a number of vehicles that the brake rotors don't just slide off to replace. How can you justify to your customer you are doing the best for them by selling them new rotors when these can really be resurfaced. Say they ask why do they need to be replaced. Your honest answer would have to be because we do not have the equipment to resurface them on the vehicle. We do not see a lot of comebacks for vibration or noise (less the 1%). If your answer is quality of new brake rotors warp easier then that's all the more reason to resurface the OE rotors do to the quality difference between them and the aftermarket. I have no argument about aftermarket quality. In general it has been going down for a while. We have seen new aftermarket brake rotors warped right out of the box.
Brian, for those type of rotors that don't slide of I plan on using a nearby machine shop that will cut them for me and adjust the invoice.
If you'd don't do enough volume to justify a lathe I completely understand. It will get to a point (hopefully) that you will be selling enough brake jobs to warrant not going through the hassle and wasted time of taking rotors to another shop and losing out on that money.
Agreed, this was excellent information from the dealer side.
Would you mind clarifying this? I'm assuming that the 2 hrs refers to techs doing both the front AND the rear, not 4 hrs for both. Just clarifying. Thanks.
Gotta start somewhere, and this way is a lot more affordable. I agree
When I was at the dealer, we got 2 hours to pads and resurface. So a 4 wheel brake job was 4 hours. Front brakes paid 2 hours. Rear brakes paid 2 hours.
Those times are per axle, so 2.0 for just the fronts and 2.0 for just the rear.
Lovely to get a ton of brake jobs at the dealer!
      In our episode today, we welcome guest Hunt Demarest, CPA ABV.
      Hunt is the host of Business by the Numbers and, as our host Craig O’Neill will tell you… Hunt uses words really well for a numbers man!
      This episode came to be after Craig found himself on a walk and listening to one of Hunts recent episodes, Episode 163 - Where are my customers?  It’s a great episode on getting to the root of what the numbers are actually telling you - and guess what - it involves actually picking up the phone and talking to people!
      Hunt’s episode played right after Craig had listened to an episode on a health/wellness program which spoke on a similar topic… going straight to the source of information!
      Often times we can get caught up in the minutia of details and analysis.
      If we are not careful - it can lead to assumptions and wrong conclusions.
      As Hunt says, “Numbers do not lie, but they do not tell the whole story.”
      Getting the whole story inevitably involves communication - and it isn’t always comfortable for people to pick up a phone to get it.
      While the takeaway for today’s episode is in the title, it expands as you listen to Hunt and Craig explore a range of topics from talking to clients, employees, and even family.
      Today’s WOTD is Gumption
      noun
      the ability to make intelligent decisions especially in everyday matters
      Learn more about Hunt Demarest here:
      https://paarmelis.com/business-by-the-numbers/
      Look for his book here:  https://a.co/d/hAf0cDF
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Mauro Stara from 6packceo.com shares powerful strategies for staying strong, sharp, and energized as a business owner. He breaks down common myths about health and highlights the importance of a personalized approach to well-being. Key areas of focus include the essential roles of sleep, nutrition, and stress management in promoting longevity and a high-quality life.
      Mauro offers practical tips for optimizing sleep by aligning with your circadian rhythm, managing light exposure, timing meals strategically, and maintaining proper electrolyte balance. He encourages listeners to treat their health like they would their car, prioritizing regular care and attention to ensure a longer, more energized life.
      Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
