Just ran into a serious issue that I want to give you guys the heads up on before it costs you a big headache. The last two Subaru timing belt jobs we did used Dayco kit, the tensioner bearing failed. The first one was after 39 miles, the second one only lasted 19 miles. These were sourced through Advance. Looks like the second one may have cost the engine.
I'm waiting to hear back on what happened in the manufacturing process that caused the failure. We have installed tons of these kits with no troubles and have two failures in a row now, something has gone sour.
Save yourself the headache, skip the tensioner or install OE on this one. Will post back with more details once I get an answer.
Edited by Junior
On this note, does anyone know for certain how many degrees the camshaft can be out before valve to piston contact on an EJ253 engine?
The SOHC 2.5 rarely bends valves. Its listed as an interference engine but I've put about 7 or 8 timing kits In cars that snapped the belt on the highway and they ran fine.
Use OE and you wont have these problems. Worldpac has Aisin which is OE aftermarket
Never had a problem with Aisin kits and I've used a ton of them. In fact, I use them so often I keep them in stock
Used Dayco hydraulic tensioner on a Pilot timing belt a few years ago and it failed within about 20k. Won't use them again. I'll stick with Gates or Aisin.
Spent a bunch of time with Dayco rep and engineers on the phone yesterday. They claim an NTN tensioner in the box, which is OE, got a new tensioner from Subaru, it is NTN, so is the Dayco one, but they are clearly different parts, different castings and everything. I can only assume NTN changed something in production or they make a different part for aftermarket. The other pulleys that come in the kit are GMB and they are identical to OE. We put OE tensioners on in place of failed ones and all is well, we got lucky with the motor that went out of time, thankfully Subaru's can be out quite a bit before interference.
I have mixed feelings about the product now, this is the only timing component failure we've seen. We switched over to Dayco from Gates only about a year ago. I'm not ready to say I won't use Dayco timing kits but I will certainly scrutinize kit components before install.
I never had good luck with Dayco when I first started my shop. Use mostly Gates for most vehicles. Continental for some specific makes/models or have a few others I use for very specific make/models.
Now that i think of it, The last dayco timing kit I bought from AZ the tensioner wouldn't expand after the pin was pulled. It was stuck in the retracted position. I used the old one because it worked better. I rarely do timing belts though because of the liability.
We installed a dayco belt on a VW beetle two weeks ago. Would not stop setting cam codes, regardless of how we adjusted the cam/crank. Turned out the belt was 1/2 tooth too small, which was just enough to throw the timing off and set a CEL. We threw an OEM VW belt on, and all was good.
    • By MikesPlaceAuto
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the Institute Summit, Mike Simard dives into the challenges of recruiting and developing talent, especially in a unique setting like Alaska. He shares his innovative strategy of acquiring lube centers as entry points for new team members and highlights the critical role of strong company culture and leadership. Mike also emphasizes the importance of building the right team, balancing the visionary and integrator roles, and the need to continuously adapt in the ever-evolving automotive industry.
      Mike Simard, Simard Automotive, Alaska
      Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Mike Simard's Background (00:00:00) Acquisition of Lube Centers (00:02:10) Energy and Problem-Solving (00:02:43) Vision for Training Talent (00:03:41) Geographic Logistics (00:05:12) Talent Development and Apprenticeship (00:05:41) Industry Comparison (00:06:32) Recruitment Challenges (00:09:04) Relocation and Recruitment Process (00:12:31) Motivation for Policy Writing (00:16:03) Understanding Unique Selling Points (00:18:05) Building a Strong Team (00:19:20) Learning from Coaches (00:21:52) Delegating Responsibilities (00:22:30) Building Company Culture (00:25:47) Understanding the 'Why' (00:27:09) Finding the Right People (00:28:34) Balancing Inner Voices (00:30:04) Breaking Barriers in the Industry (00:30:35)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Overcoming Guilt (00:03:04)
      chris autofixsos.com
