Ok, before you all begin assaulting and attacking me for being a half ass mechanic...let me explain:
I AM NOT posting this because I make a practice of replacing only one brake rotor or because I want to argue a case in favor of such practice. I, like most of you I imagine, have always been taught and trained to replace/refinish brake rotors ONLY in pairs. NO EXCEPTIONS. Or else the world will explode! haha...ok, well, maybe not the world I guess. But presumably something really bad will happen.
But do any of you ever get asked by the customer WHY you had to replace both rotors when only one was "bad"? What do you tell them? Do you just make something up, spout off the same generic response that your old boss/instructor/teacher/mentor, etc. told to you about how you need rotors of the same thickness for equal stopping force blah blah blah or do you actually KNOW the concrete scientific reasoning behind this "universal truth"? I myself am a little fuzzy on the details. It seems like I am constantly having to explain to customers that I had to replace BOTH brake rotors, but when they ask me why, I don't really know exactly. I'm hoping you guys can help me out with either a detailed explanation or a link to some technical artical that will explain it.
I will also accept personal experience as evidence such as "I tried replacing only one rotor one time and the customer was back the very next week in a full body cast with his lawyer pushing the wheel chair."
Ready: GO
I was taught that it maintains even braking. If the old rotor is thinner it will build heat and thus fade faster than the new one. That in turn will develop a brake pull that could cause loss of control.
I believe this is the correct answer, although I think the potential safety issue is very minimal IMO. Don't forget that you almost always have a slight brake pull due to the crown of the road.
I also think that refinishing/replacing in pairs is to keep both sides wearing at the same rate, so if one is worn out, the other will be soon to follow.
That being said, I work at a heavy duty dealership at the moment, and we regularly replace single rotors on commercial trucks with disc brakes if the other is still within spec.
If I was in your situation, I'd measure the "good" rotor, estimate how much time is left before it fails, and inform the customer.
Educate them to the cost of fixing it now vs returning for another appointment where you have to disassemble that wheel end again.
Obviously recommend changing rotors in pairs, but if they don't want to, I wouldn't press the issue.
If the rotor will last until their next scheduled maintenance, maybe they'd want to have it replaced then, always give your customer the choice.
This is a really good question. I would say 'technically' you can replace just 1 rotor. After all, if the other one is within spec... it's within spec! I would say 'replacing as a pair' is probably more of a good practice, IE Jeff - " If the old rotor is thinner it will build heat and thus fade faster than the new one. That in turn will develop a brake pull that could cause loss of control" .
I would also agree, now that I think about it, that I don't recall reading or hearing any official material say that they should be replaced in pairs... Maybe a quick google search would turn something up?
I think the brake pull is a good answer but could lead to the question of if you think its unsafe then why would you perform that practice and open yourself up for potential law suit after admitting to cust that it could cause loss of control. I usually play the economic card...saves money to do it now. Then let cust decide, assuming rotor is within spec.
i always use things that people can relate to like the LP record and the sun analogy. Heat will warp a record like heat will warp the rotors.. so in this case i tell customers that brake rotors should be replace together because they both have to be the same thickness and then i tell them if they would you ever consider buying only one shoe. if only one shoe gets worn will they just buy that warn shoe? after that what can you say "I under stand, go ahead and replace them.." Done "Change them Bob..."
Edited by uniautoser
I will do one rotor as long as I turn both the rotors for a matching finish. Of course the other rotor needs to be within spec after the refinish. This scenario does not come along often for me.
Most of my clients have never played an LP Record, and if I used that term most would not have a clue what I was talking about. I have not seen one out of its protective sleeve in well over 30 years!!
With that said, When I give a price on performing the brake job on a vehicle that is in the shop with wheels off and inspection finished, I give the price for the brake job. I do not mention pads or more importantly, rotors. I tell them that the price for the front brakes is $388 for example, and that the rear brakes are ok at this time. I would say that on 80% or more of my brake jobs I install new rotors. We do not machine rotors.
Replacing rotors in pairs helps keep consistency in maintenance, and safety. By doing so you remove the guessing game of when you need to do it again, and basically the customer trades some dollars for convenience and certainty.
Kinda, doing light bulbs in pairs, you know, I am sure you had a customer come in for a burned out headlight bulb and a few weeks later he comes in again for the other one.
There are customers that if you explain to them that they may have to comeback for the other bulb, they dispense with the inconvenience and tell you to do both.
      In this episode, Craig is concise as he reflects on the timeless wisdom of Martin Luther King Jr. and how his principles of nonviolent conflict resolution remain highly relevant today. Inspired by recent readings of King’s works, specifically his iconic Letter from Birmingham Jail, Craig explores how these lessons can be applied to resolving conflicts in everyday life—even in situations as modern as addressing negative reviews.
      This thoughtful discussion acknowledges the historical context of King’s writings while highlighting their enduring value in promoting understanding, negotiation, and meaningful resolution.
      Key Points Discussed:
      Craig’s Appreciation for MLK’s Legacy: Acknowledging King’s brilliance as a leader, communicator, and writer, Craig emphasizes the enduring relevance of his concepts and principles. The Four Steps of a Nonviolent Campaign (as outlined in Letter from Birmingham Jail):
      Collection of Facts: Ensure injustices are present and verified. Negotiation: Open dialogue with a willingness to find common ground. Self-Purification: Prepare yourself to act constructively and maintain the ability to return to negotiation. Direct Action: Take deliberate action aimed at fostering a return to negotiation.
      The Word of the Day:
      Unfettered.
      Adj - Not controlled by anyone or anything.  Uninhibited
      Modern Applications:
      Craig draws parallels between these steps and common missteps in conflict resolution today, such as skipping fact-gathering and jumping straight to retaliation—like leaving a low review without understanding the full story. He discusses how these missed steps can lead to escalation rather than resolution.
      Takeaways for Listeners:
      People care about how much you know only after they know how much you care. Applying MLK’s principles to situations like resolving a customer complaint or an unjust review can model constructive engagement and encourage others to seek facts, negotiation, and resolution.
      This episode is a thoughtful tribute to King’s enduring legacy and a practical guide for applying his lessons to resolve conflicts with empathy and integrity.
      Links & Resources:
      Letter from Birmingham Jail by Martin Luther King Jr.
      Join Craig as he unpacks these timeless lessons and their power to transform the way we approach conflicts in our personal and professional lives.
      In this episode of "The Weekly Blitz," host Coach Chris Cotton opens up about his deeply personal journey with grief following the passing of his beloved wife Kimberly's mother on New Year's Eve. With heartfelt sincerity, he delves into the complex and often overwhelming stages of grief, sharing insights and reflections from his own experience. Chris emphasizes the crucial importance of being prepared for the inevitable reality of loss, introducing listeners to the "red envelope yellow envelope" concept. This thoughtful approach involves meticulously documenting essential information and end-of-life plans, ensuring that loved ones are not left in the dark during times of emotional turmoil.
      Chris underscores the necessity of having those often uncomfortable yet vital conversations about end-of-life wishes and preparations. By addressing these topics head-on, individuals can significantly ease the burden on their families and friends, allowing them to focus on healing and remembrance rather than logistical challenges. Throughout the episode, Chris also touches on the emotional and spiritual dimensions of grief, offering guidance and support to those navigating similar paths.
      He encourages listeners to prioritize self-care and preparedness, not only in their personal lives but also within their business endeavors. By fostering a mindset of readiness and resilience, individuals can better cope with the unpredictable nature of life and loss. Through his candid storytelling and practical advice, Coach Chris Cotton provides a compassionate and empowering message, reminding us all of the strength found in vulnerability and the peace that comes from being prepared.
      Introduction to the Episode (00:00:01)
      Coach Chris Cotton introduces the podcast and its focus on auto repair business insights.
      Happy New Year Message (00:01:13)
      Chris shares a New Year greeting and hints at personal challenges faced recently.
      Discussion of Loss (00:02:29)
      Chris reflects on the passing of Kimberly's mother and the impact on their family.
      Red Envelope Yellow Envelope Concept (00:03:46)
      Importance of planning for unexpected events is emphasized through personal experiences.
      The Emotional Toll of Grief (00:06:50)
      Chris describes the emotional reactions and support needed during grief.
      Organizing Affairs for Loved Ones (00:08:18)
      Advice on preparing personal and business affairs to ease burdens on family.
      The Stages of Grief (00:10:27)
      Chris outlines the stages of grief observed in Kimberly's reactions to loss.
      Denial and Anger Stages (00:11:38)
      Discussion of denial and anger stages in the grieving process.
      Bargaining Stage of Grief (00:13:08)
      Explains how bargaining manifests in thoughts of regret and "what if" scenarios.
      Depression and Acceptance Stages (00:15:12)
      Chris describes the transition between depression and acceptance in the grieving process.
      Call to Action for Planning (00:16:28)
      Encouragement to have plans in place for end-of-life situations to support loved ones.
      Importance of Life Stories (00:17:47)
      Chris stresses the need to document loved ones' life stories before it's too late.
      Final Thoughts on Grief and Readiness (00:19:00)
      Reflection on being spiritually and emotionally prepared for life's uncertainties.
