We use brake clean as well. You can use the non-chlorinated version. However, we have found a cleaner called Drive-up that is made to clean oil from concrete but a solution of it works great as a degreaser on engines. It is not a petroluem based product but must be some type of akaline. It does not have any obnoxius odor or fumes. Driveup is a good product.
http://www.driveupusa.com/store/dynamicIndex.asp
Cool thanks. I will ask around for this.
I use a crap load of brake cleaner because I am very particular about my stuff being clean when I am done with the repair. I know is probably not good for me and I know first hand that it burns like crap when you get it in the eyes :) I will have to see if I can get this stuff at my Oreillys which it shows sell it.
Not to scare you, but a good friend of mine is a machinist and used brake cleaner to clean parts for more than 20 years. He recently had a kidney transplant for a failed kidney.
The doctors attributed to brake cleaner!
That's still scary Joe....
If we could look through the microscope at almost anything these days, we would probably all be running for the wide open country. I used to spray a lot of Dupont Imron paint years ago and today I feel I'm suffering from the affects it had on my central nervous system. (It had Cyanide in the formula)
I just wanted to mention the we manufacturer a very special soap for cleaning brake parts, we needed something to go along with our OE Approved "5 Step" Brake Procedure ( www.StopBrakeNoise.com ).
You simply mix a couple of tablespoons of the powder in a gallon of water and your have a solution that is perfectly matched to the surface of a rotor or drum. By that I mean, the surfactants, anti corrosives and lack of oil, make it perfect for demagnetizing and cleaning of the pores. This is a critical if you want to eliminate potential problems when the rotor or drum heats up on the vehicle. When that happens, any remaining metal particles from the cut works their way out and into the pad surface and cause excessive noise. ( www.BrakeSoap.com )
Best part is the GWR Brake Soap is biodegradable and costs less than .05 cents to properly clean a vehicle's brake system. Be careful comparing this to a couple of cans of brake clean per vehicle, times the number of jobs per year, you'll have a heart attack. Even if you don't use our soap for other services, doing brakes is a large consumer of brake cleaner in today's shop. If you figure only a case or two a week of sprays, using Brake Soap can save you $500 to well over a $1,000 per year.
Hope this is of value...
Gary
1(800) 266-4497
www.GWRauto.com
Gary
1(800) 266-4497
www.GWRauto.com
I must chime in here. I have been using Garys soap along with his other products for about 5 years now. The brake rotor hone and rotor conditioning spray are two products my brake techs will not be without. I must admit that we use the soap to wash each newly machined rotor but have not tried it as a way to clean prior to starting service. Is that what you suggest Gary?
Hi Curt,
Thanks so much for posting your experience with our brake products, I really appreciate you taking the time to let the members of the group know we have viable solutions to service problems.
As to your question on using the Brake Soap during disassembly, I have used it for that work with good results. I would base the decision on whether or not the parts are caked with heavy, greasy contaminants. Our specially formulated soap is not intended to cut heavy grease but rather to go deep in to the pours of the cast iron rotors and drums, to demagnetize and pull out the loose metal parts. If the parts are really dirty (greasy) us a serious degrease type product before the cutting and honing process. As a note, if the rotor or drum is rusted and dry, I highly recommend using a simple sand blaster (table top or cabinet style, etc) to remove rust and clean surface to a shine. From there you can rinse in our brake soap liquid before going to the lathe. It is imperative you have a shiny surface in the hat areas (adapter mating surfaces), before setting up on the lathe, otherwise you will induce run-out and create an out of spec part.
If a shop is still using brake clean to prepare a rotor for assembly, they are behind the curve nearly 10 years. In tests done over 7 years ago at Aimco (largest mfg of brake rotors), it was determined a soap and water cleaning of rotors or drums removed 40% to 60% more of the loose metal introduced during the cutting process. The properly washed rotors, the ones cleaned with soap and water, retained less than 3% metal while the brake cleaned rotor retained 25% to 35%.
If metal particles are left in the rotor or drum surface, when they are heated during the braking cycle, the metal will work it way out and impregnate the pad surface. This will case excess heat to build during the stop but of more concern is the chance for noise.
Please call me and get some Brake Soap, you will never go back to expensive brake clean. Better, you will be providing your customer with the best brake job possible.
Gary
1(800) 266-4497
  • 6 months later...
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Host Carm Capriotto speaks with Jay Goninen, co-founder and president of WrenchWay, about insights from the 2026 Voice of the Technician Survey and what it reveals about the state of the automotive workforce.
      Jay encourages shop owners to download the free report to uncover blind spots and start meaningful conversations with their teams. The data show that technicians strongly prefer a four-day, 10-hour workweek with no weekends, along with proper equipment, paid vacation, retirement benefits, and paid training.
      While dealership technicians made up a larger share of respondents, independents stood out in workplace culture. 63% of independent technicians would recommend their shop to a friend, compared to 36% at dealerships, though dealerships scored higher in providing paid training. Across both groups, technicians favor an hourly wage plus bonus structure, which many feel better supports diagnosticians than traditional flat-rate systems.
      The discussion also highlights a troubling trend: the industry’s Net Promoter Score dropped to -60 in 2026, signaling that many technicians would not recommend the profession to others.
      To strengthen the talent pipeline, Jay discusses ASE Connects, a new initiative aimed at connecting shops with high school and technical school automotive programs to support them through mentorship, advisory roles, and community engagement.
      Carm also advocates elevating the profession by shifting the language from “mechanic” or “technician” to “specialist,” emphasizing the expertise required to work on today’s vehicles.
      Overall, the episode serves as a wake-up call for shop owners to use the survey insights to evaluate their culture, communication, and work environments, and to become employers technicians are proud to recommend.
      https://wrenchway.com/resources/2026-voice-of-technician-survey-report/
      Jay Goninen, Co-Founder and President, WrenchWay
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Connect with the Podcast: - Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ - Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters - Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 - Subscribe on YouTube: https://www.youtube.com/carmcapriotto - Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ - Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ - Visit the Website: https://remarkableresults.biz/ - Join our Insider List: https://remarkableresults.biz/insider - All books mentioned on our podcasts: https://remarkableresults.biz/books - Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom - Buy Me a Coffee: https://www.buymeacoffee.com/carm - Special episode collections: https://remarkableresults.biz/collections - The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ - Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ - Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ - Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ - The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ - The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ - Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                         Click to go to the Podcast on Remarkable Results Radio
    • By Hands On
      The emailed me a form to sign up to be a "service provider" The company Service Up will send me the client. They will bill the client and pay me after the repair. Look at some of the highlights from the terms:
       All transactions completed through the Platform are subject to a transaction fee ranging from 1.99% to 10% of the gross amount of each repair, with a baseline marketplace fee of 3.99% unless otherwise specified in a fleet-specific addendum.
      The marketplace fee applicable to a given repair is one of the following:
      • 3.99% (baseline) of the gross amount of all repairs completed through the Platform for all other customers, including customers to whom ServiceUp has referred you.
      • A rate specified in a fleet-specific addendum, which overrides the baseline, provided such rate falls within the 1.99%–10% range stated above.
      In addition to the marketplace fee, the following optional fee may apply:
      • QuickPay fee — an additional 3.50% of the gross amount of the repair if you elect to receive early payment (typically next business day). In the event a credit card is used by the customer for payment, the 3.50% QuickPay fee will be automatically applied.
      So, the fee they charge is any where from 1.99% to 17% if they pay credit card and you want funds next day
      Company reserves the right, in its sole discretion, to modify, increase, decrease, or otherwise change the transaction fees, early payment fees, or any other amounts payable under these Terms at any time.
      But those fees could go up with no notice at all
      The Company shall remit payment to you net of any applicable transaction fees as promptly as practicable after, and contingent upon, Company’s receipt of payment from the applicable fleet customer for the services rendered by you.
      They will pay you for the work you did, as long as they are able to get paid.
      You acknowledge and agree that the Company shall not be responsible for any delays or failure to pay that may be caused by a fleet customer.
      And if the customer fails to pay them, too bad.
      You further acknowledge and agree that (i) the Company may withhold funds in the event of any dispute between you and the Company pending the resolution of such dispute, (ii) you shall not collect any fees for services rendered hereunder directly from a fleet customer and shall receive payment for such services solely from the Company, (iii) in the event the Company determines that you have violated the foregoing subsection (ii), the Company shall have the right to charge a penalty of 10% of the gross value of the applicable services and may withhold that amount from future payments or debit your bank account to recover the penalty and any applicable fees for services.
      AND if they customer fails to pay them and you go directly after the customer yourself, tack on another 10%
      So basically, you fix our cars, and we maybe pay you after we take fees.
      Has anyone used this platform? What do you think?
      Why Technician Pay Isn’t the Real Problem
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Dan Vance, CEO of Shop Dog Marketing, challenges how auto repair shops think about marketing in today’s AI-driven world. The conversation goes beyond websites and SEO, exploring how real marketing lives in every customer interaction and how tools like ChatGPT and Google AI Overview can become powerful strategic partners.
      What You’ll Learn
      Marketing Is Bigger Than Digital Tactics: Most shops mistake marketing for SEO, ads, or websites. Dan reframes marketing as theentire customer experience,from the way a repair is explained to how a customer feels in your waiting room. The shops that win combine smart digital strategy with authentic human connection. Why “Precious Moments” Builds Powerful Brands: Small, meaningful experiences, like a child choosing a toy or a team member giving back to the community, create emotional anchors. Capturing and sharing these moments builds trust and a brand that customers remember and talk about. How E-E-A-T Drives Visibility and Growth: Search engines prioritize Experience, Expertise, Authority, and Trust. Shops that intentionally showcase these qualities can outperform larger competitors. Long-term credibility matters more than short-term ad spend. Using AI as Your Strategic Thinking Partner: AI isn’t just a tool; it’s a collaborator. Dan shares practical ways shops can use it: Identify dealership weaknesses through review analysis and position your shop as the better alternative. Understand your shop’s real online reputation, both strengths and blind spots. Improve hiring by comparing candidates to your top performers and analyzing interview traits.
      Stop thinking of marketing as something you do and start seeing it as something you are. When you combine authentic customer experiences with the strategic power of AI, you don’t just compete, you create momentum that builds trust, visibility, and long-term growth.
      When Customers Ask AI First: What Shop Owners Need to Know [RR 1071]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1071/
      Dan Vance, Shop Dog Marketing.com
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Connect with the Podcast: Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Buy Me a Coffee:https://www.buymeacoffee.com/carm Special episode collections:https://remarkableresults.biz/collections
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Zwith Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numberswith Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcastwith Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitzwith Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communicationwith Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.https://craigoneill.captivate.fm
      Vehlo CEO Reveals What's Actually Changing the Automotive Industry in 2026
