Searched and don't see this topic anywhere:
What is the average length of time that shops use for labor warranties? We for the most part say it's lifetime on labor because we stand behind our work and if we did it wrong, we'll fix it. But I think that some people (!) would take advantage of that fact and that with some types or repairs or work, past a certain point in time, you couldn't prove labor issue, part issue or wear and tear, so what's an acceptable time frame for both customer and shop? 12k/12 month? Interested in hearing how everyone handles this issue.
This is something I've thought of a lot as well. Having a strong warranty and using top quality parts is definitely a great selling feature for you.
I'm guessing most "rat hole" type shops would run a 3 or 6 month warranty.
From what I've seen, the most common would be a 12/12 warranty.
A premium shop using top quality parts could easily offer 24/24 or even more if using dealer parts.
thanks appreciate the feedback. We have a large customer base that has a poor history of vehicle maintenance so I am leaning toward 12/12.
24/24 because we are a part of the Certified Auto Network with Oreilly's. Nationwide and the few times my customers have had to use it on the road, the warranty has worked very well.
I am 30days on used parts with no labor warranty unless purchased seperately from part supplier (engine, transmissions, rear ends etc).
1 Year unlimited miles on brake pads, rotors, starters, alternators, pretty much everything else.
My cliental can be kind of rough with the working class area I am in. Customers always come back trying to warranty stuff that is unrelated to the repair you did. Example I installed a LKQ motor in a Ford Fusion with a 12 month, 12k warranty purchased from LKQ, covers internal lubricated part. Within a year the Alternator went out, customer wanted it warrantied, and one of the accessories pullies started making noise and they wanted that warrantied. Big fuss over everything, but they act like a warranty is bumper to bumper for the next year.
Mario - share your pain. Same situation here. You look under the hood and you own it for life. Trying to avoid those arguments with customers. They want the cheap fix with cheap parts and labor, don't maintain the vehicle and then everything that goes wrong is supposed to be on us. Extremely frustrating and discouraging.
We are 12/12 here. If there is a life time warranty on the part, then we will pass that on to the customer, but they need to pay the labor if it is out of warranty.
A warranty is a positioning statement. It is part of your marketing and risk management. It doesn't matter how long your warranty is, simply factor the cost to cover into cost of operations. Customer perceived coverage is unconditional. If it fails for what ever reason it's on you.
Ive wondered about this in my area. Im 12/12 currently. Thinking of changing it to fit the warranty im given from my suppliers. They have recently changed labor claim warranty to only 90 days. So was considering 90 day labor and 12 parts. But also have considered lifetime warranty options parts and labor. Feedback would be helpful.
My shop is a NAPA AutoCare Center and NAPA provides a 24 month or 24,000 mile nationwide warranty on most parts. So do I. If the part has a lifetime warranty I extend that to the customer as well and tell them the limited poriton is the part is warranted for the life of their ownership of the vehicle but the labor is covered for months. in the event i lose my sanity and install a used part, 30 day part only, NO LABOR. In the event I go insane and install a customer supplied part, NO WARRANTY WHATOSEVER beyond I did the job right. Starter falls out, I didn't do the job right, starter solenoid stops engaging or the solenoid to starter motor wire corrodes but the starter is mounted tight and the cables are clean and secure, I did the job right no warranty. As an example of course.
If your supplier screws you on labor reimbursement you can do one of three things, eat it in the event of a parts failure, hopefully not very often, build your own warranty costs into your rates or find a better supplier who will stand behind you better. NAPA stands behind their AutoCare Centers for the full term of the warranty. It is reimbursed at a reduced rate, I think it's 75% but that's better than 0%.
we offer a 12/12 warranty but nobody reads it. If they have a repeat failure within a year they come back anyway and we fix it. If they have a repeat failure anytime we do our best to make it right for them regardless of time/miles. If it's caused by neglect or brother in law tinkering too bad the customer pays, If it's a parts defect we take care of it and try to get a labor claim. Technician workmanship problems usually show up quickly, like immediately :). Bigger jobs like transmissions come with a 3 year manufacturers parts and labor warranty (at a reduced rate of course), we build it into the estimate. Usually if a part has a recurring failure something else is wrong and we learn from it. Some customers expect too much, like they never check tire pressure and never rotate their tires never fix the loose tie rod and broken springs and cry when they don't get the 60k miles they were promised. We don't give charity. Customer supplied parts come with zero warranty - we try our hardest to talk them out of it but if all else fails we accept their diagnosis, install their parts, and take their money, that's it. Funny story we installed a starter for a guy on a F150, he supplied it. Didn't start before or after, just a loud click. We offered to check into it but He knows it all so he had us put in another one. Same result. He really is an expert so he had us install a 3rd one. Before pulling the 3rd junkyard starter I gave some free diagnostic labor and it turns out the AC compressor was locked up solid.Removed the belt and the starter was good again (I can assume the 1st one was good too along with the new battery he installed and a host of new easy to replace parts under the hood someone put in). He was mad we charged him to R&R 3 starters I'm soft so we made a deal but I shouldn't have.
We do the 30/30, 30 feet or thrity seconds which ever comes first.....lol. Seriously though we also do the 12/12. No warranty on labor or parts if used even if we supply it. I offer that option to my customer but make sure they understand. After reading some of the situations posted above I see a common situation which can usually be avoided if your service writer/counter person does a good job explaining what is and isn't covered when an job is performed. We all have THOSE customers who expect something for free, but once again my service writer handles those situations easily due to the fact that upon the initial job everything we see is documented on the customer invoice. As for what Alfred just typed, we won't let customers tell us to replace parts without US diagnosing. If they wont pay my diag fee then I don't want them as a customer. I have seen first hand who loses when a customer self diagnoses his vehicle and supplies a part. If it doesn't work then the shop who did the work doesn't feel good about the repair and neither does the customer. Those customer usually leave and give negative publicity. Although it wasn't the shops fault, who pays the price when slandered. My .02c
Edited by Chuck
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Most auto repair shops are sitting on a goldmine of untapped revenue without realizing it.
      In this episode, Carm Capriotto welcomes Jimmy Alauria of 3A Automotive & Diesel Repair to discuss how deferred work can become one of your shop's most effective growth strategies. By pulling just two years of data from his shop's database, he discovered $3.3 million in potential revenue from deferred services. From better customer communication to smarter follow-up systems, Jimmy explains how to turn yesterday's declined repairs into tomorrow's repair orders.
      What You'll Learn Why your customer database is one of your shop's most valuable assets. How deferred work can create significant new revenue without increasing car count. Why shops should schedule the next appointment before the customer leaves. While DVIs provide excellent transparency, their primary goal should be to educate the customer and help them plan, rather than to force an immediate $5,000 repair order. Jimmy notes that customers decline work not necessarily because they lack trust, but because they need time to budge How categorizing repairs by safety, reliability, maintenance, and appearance improves customer understanding. Understanding the customer's personal "car goals," whether they love the car and want to avoid a new car payment, or they hate the car and want to trade it in, is also critical to framing recommendations effectively. The shortcomings of traditional CRM follow-up systems and how AI can improve communication. How AI helps prioritize repairs and translates technical repair language into customer-friendly messaging that drives response.
      Deferred work isn't lost business; it's future opportunity. By building better follow-up processes, educating customers, and using technology to communicate more effectively, shops can strengthen relationships, improve customer retention, and unlock substantial revenue already waiting in their database. Jimmy Alauria, 3A Automotive and Diesel Repair, Phoenix, AZ. Jimmy’s previous episodes HERE Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://remarkableresultsradiopodcast.captivate.fm/napaautocare   NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/
      Download and Listen on Our Mobile App:https://automotiverepairpodcastnetwork.com/app/ Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Special episode collections:https://remarkableresults.biz/collections Buy Me a Coffee:https://www.buymeacoffee.com/carm
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto:Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z:From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numbers: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitz: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communication: Develop Interpersonal and Professional Communication Skills with Craig O'Neill.https://craigoneill.captivate.fm
    • By TradeHop
      Hey all — long-time lurker, first post. I'm building something called TradeHop and want to sanity-check the idea with people who actually run shops before I go further.
      The concept: traveling or independent mechanics book your spare bay time by the day instead of you hiring them full-time. You set the price and hours, they book, and you keep the bay filled on slow days instead of empty.
      Before I build more, I'm curious: would any of you actually consider doing this, and what would make you say no? Not trying to sell anything here, genuinely want the reality check from people who run shops for a living.
      Welcome to our live show!
    • By sparkerauto
      Hello just seeing if any of you guys are part of this program threw carquest or advance auto ? I have been part of it for almost a year now and i am not seeing any benifits besides the 24/24 warranty. Mostly because the person at the store we us does not go over things with us. Was just looking to seeing how some of you guys are benifiting from this program. Thanks
      Hi, y'all.
      I was wondering if anyone could recommend someone that is producing good quality content for autorepair websites or blogs.
      Harry
