Hello, I am looking for a printable multi-point check list that i could give to my techs to fill out on every car. Does anyone have one that the would be willing to share with me ? Thank you very much !
As a member of TECHNET Professional you have access to all AMRA MAP vehicle inspection forms which you can access through the TECHNET Member's portal, www.members.technetprofessional.com.
Click on Grow Your Business and then select Motorist Assurance Program. The inspection forms are toward the bottom of the page in the Resource Library.
Hope this helps,
Use the check list that works for your shop. Our shops use derivative lists of the main list. But the point is that the check list that enables you the most upsells that work is the one you want to be using.
Don't forget to check the customers credit score.
Just a simple check of Mileage based needs, Fluids,Filters,Lights, Brakes and Tire age/wear reveals alot.
Always check fluid levels on check in. Many cars will come in with no oil reading on the stick.
Edited by FROGFINDER
So true!
If you have been doing this for a while, the way you process a car will reveal much before you even lift a car.
So true!
To show a customer obvious service needs on check in paves the way for immediate up sell.
      “Do I have enough to retire?”
      What You'll Learn:
