Searched and don't see this topic anywhere:
What is the average length of time that shops use for labor warranties? We for the most part say it's lifetime on labor because we stand behind our work and if we did it wrong, we'll fix it. But I think that some people (!) would take advantage of that fact and that with some types or repairs or work, past a certain point in time, you couldn't prove labor issue, part issue or wear and tear, so what's an acceptable time frame for both customer and shop? 12k/12 month? Interested in hearing how everyone handles this issue.
This is something I've thought of a lot as well. Having a strong warranty and using top quality parts is definitely a great selling feature for you.
I'm guessing most "rat hole" type shops would run a 3 or 6 month warranty.
From what I've seen, the most common would be a 12/12 warranty.
A premium shop using top quality parts could easily offer 24/24 or even more if using dealer parts.
thanks appreciate the feedback. We have a large customer base that has a poor history of vehicle maintenance so I am leaning toward 12/12.
24/24 because we are a part of the Certified Auto Network with Oreilly's. Nationwide and the few times my customers have had to use it on the road, the warranty has worked very well.
I am 30days on used parts with no labor warranty unless purchased seperately from part supplier (engine, transmissions, rear ends etc).
1 Year unlimited miles on brake pads, rotors, starters, alternators, pretty much everything else.
My cliental can be kind of rough with the working class area I am in. Customers always come back trying to warranty stuff that is unrelated to the repair you did. Example I installed a LKQ motor in a Ford Fusion with a 12 month, 12k warranty purchased from LKQ, covers internal lubricated part. Within a year the Alternator went out, customer wanted it warrantied, and one of the accessories pullies started making noise and they wanted that warrantied. Big fuss over everything, but they act like a warranty is bumper to bumper for the next year.
Mario - share your pain. Same situation here. You look under the hood and you own it for life. Trying to avoid those arguments with customers. They want the cheap fix with cheap parts and labor, don't maintain the vehicle and then everything that goes wrong is supposed to be on us. Extremely frustrating and discouraging.
We are 12/12 here. If there is a life time warranty on the part, then we will pass that on to the customer, but they need to pay the labor if it is out of warranty.
A warranty is a positioning statement. It is part of your marketing and risk management. It doesn't matter how long your warranty is, simply factor the cost to cover into cost of operations. Customer perceived coverage is unconditional. If it fails for what ever reason it's on you.
Ive wondered about this in my area. Im 12/12 currently. Thinking of changing it to fit the warranty im given from my suppliers. They have recently changed labor claim warranty to only 90 days. So was considering 90 day labor and 12 parts. But also have considered lifetime warranty options parts and labor. Feedback would be helpful.
My shop is a NAPA AutoCare Center and NAPA provides a 24 month or 24,000 mile nationwide warranty on most parts. So do I. If the part has a lifetime warranty I extend that to the customer as well and tell them the limited poriton is the part is warranted for the life of their ownership of the vehicle but the labor is covered for months. in the event i lose my sanity and install a used part, 30 day part only, NO LABOR. In the event I go insane and install a customer supplied part, NO WARRANTY WHATOSEVER beyond I did the job right. Starter falls out, I didn't do the job right, starter solenoid stops engaging or the solenoid to starter motor wire corrodes but the starter is mounted tight and the cables are clean and secure, I did the job right no warranty. As an example of course.
If your supplier screws you on labor reimbursement you can do one of three things, eat it in the event of a parts failure, hopefully not very often, build your own warranty costs into your rates or find a better supplier who will stand behind you better. NAPA stands behind their AutoCare Centers for the full term of the warranty. It is reimbursed at a reduced rate, I think it's 75% but that's better than 0%.
we offer a 12/12 warranty but nobody reads it. If they have a repeat failure within a year they come back anyway and we fix it. If they have a repeat failure anytime we do our best to make it right for them regardless of time/miles. If it's caused by neglect or brother in law tinkering too bad the customer pays, If it's a parts defect we take care of it and try to get a labor claim. Technician workmanship problems usually show up quickly, like immediately :). Bigger jobs like transmissions come with a 3 year manufacturers parts and labor warranty (at a reduced rate of course), we build it into the estimate. Usually if a part has a recurring failure something else is wrong and we learn from it. Some customers expect too much, like they never check tire pressure and never rotate their tires never fix the loose tie rod and broken springs and cry when they don't get the 60k miles they were promised. We don't give charity. Customer supplied parts come with zero warranty - we try our hardest to talk them out of it but if all else fails we accept their diagnosis, install their parts, and take their money, that's it. Funny story we installed a starter for a guy on a F150, he supplied it. Didn't start before or after, just a loud click. We offered to check into it but He knows it all so he had us put in another one. Same result. He really is an expert so he had us install a 3rd one. Before pulling the 3rd junkyard starter I gave some free diagnostic labor and it turns out the AC compressor was locked up solid.Removed the belt and the starter was good again (I can assume the 1st one was good too along with the new battery he installed and a host of new easy to replace parts under the hood someone put in). He was mad we charged him to R&R 3 starters I'm soft so we made a deal but I shouldn't have.
We do the 30/30, 30 feet or thrity seconds which ever comes first.....lol. Seriously though we also do the 12/12. No warranty on labor or parts if used even if we supply it. I offer that option to my customer but make sure they understand. After reading some of the situations posted above I see a common situation which can usually be avoided if your service writer/counter person does a good job explaining what is and isn't covered when an job is performed. We all have THOSE customers who expect something for free, but once again my service writer handles those situations easily due to the fact that upon the initial job everything we see is documented on the customer invoice. As for what Alfred just typed, we won't let customers tell us to replace parts without US diagnosing. If they wont pay my diag fee then I don't want them as a customer. I have seen first hand who loses when a customer self diagnoses his vehicle and supplies a part. If it doesn't work then the shop who did the work doesn't feel good about the repair and neither does the customer. Those customer usually leave and give negative publicity. Although it wasn't the shops fault, who pays the price when slandered. My .02c
Edited by Chuck
      Welcome to our live show!
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Recorded live at the 2026 TST Big Event, Carm Capriotto sits down with automotive trainer Ken Zanders to discuss the importance of ongoing technical education, building efficient diagnostic processes, and adapting to rapidly evolving vehicle technology. Ken explains why too many shops still rely on a chaotic “grocery list” approach to repairs and how a structured diagnostic strategy can dramatically improve technician efficiency, profitability, and customer trust.
      What You’ll Learn
      Why inefficient diagnostic habits directly reduce technician productivity, shop profitability, and overall earning potential. The importance of following a structured diagnostic workflow instead of guessing and replacing parts. How electronic relative compression testing with a lab scope and amperage probe can reduce diagnostic time from hours to minutes. How modern vehicle technologies like GM’s Vehicle Intelligence Platform (VIP) and Over-The-Air (OTA) updates are changing diagnostics and repair procedures. Why continuous education is no longer optional for automotive professionals working on today’s advanced vehicle systems.
      The biggest takeaway from this episode is that repair shops cannot afford to operate in constant chaos and guesswork. A reactive “grocery list” approach to diagnostics leads to wasted time, unnecessary parts replacement, lower profits, and poor customer outcomes. To succeed in today’s increasingly complex automotive industry, shop owners must create a year-round training strategy that helps technicians diagnose efficiently, think critically, and continuously improve their skills. Structured processes, modern testing methods, and ongoing education are no longer advantages; they are necessities for survival and growth.
      TST Big Event: https://tstseminars.org/
      Ken Zanders, Dorman Training
      Don’t Base Your Success On Probability – Ken Zanders [RR 822]: https://remarkableresults.biz/remarkable-results-radio-podcast/e822/
      Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care
      NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/
      Visit the Website: https://remarkableresults.biz/
      Subscribe on YouTube: https://www.youtube.com/carmcapriotto
      Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/
      Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 Join our Insider List: https://remarkableresults.biz/insider All books mentioned on our podcasts: https://remarkableresults.biz/books Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom Special episode collections: https://remarkableresults.biz/collections Buy Me a Coffee: https://www.buymeacoffee.com/carm   The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                                          Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA TRACS, Today's Class, KUKUI, and Pit Crew Loyalty Watch Full Video Episode Carm Capriotto talks with Matt Curry and Judy Curry of Craftsman's Auto Care about building one of the automotive industry’s most respected multi-shop operations twice.
      After growing Curry’s Auto Service to 10 locations and retiring in 2013, the Currys returned to the industry with a new vision, launching eight Craftsman’s Auto Care locations in eight years. Matt shares his role as the visionary leader driving momentum and ideas, while Judy explains how operational discipline, marketing, and customer experience keep the business grounded and scalable.
      The conversation explores their “5 Ps” philosophy: People, Policies, Processes, Procedures, and Profits, along with their commitment to employee development, strong culture, customer transparency, and community involvement. The Currys also discuss how Digital Vehicle Inspections and an intentional customer experience helped them earn nearly 10,000 five-star Google reviews.
      What You’ll Learn
      How Matt and Judy Curry scaled multiple successful shop operations Why leadership balance and “staying in your lane” matters The “5 Ps” framework for building a strong shop culture How employee investment drives long-term success Why transparency and DVIs build customer trust How culture and customer experience fuel growth and retention
      Sustainable growth in automotive repair comes from more than technical expertise. It requires intentional leadership, strong systems, a healthy culture, and a commitment to both employees and customers.
      Matt and Judy Curry, Craftsman Auto Care, 8 locations, Virginia Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Thanks to our Partner, KUKUI Stop juggling multiple marketing tools. KUKUI’s integrated platform delivers 4x better website conversions, automated follow-up, and real-time ROI tracking. Get industry-leading customer support with KUKUI at https://www.kukui.com/ Thanks to our Partner, Pit Crew Loyalty You’re probably tired of chasing new customers who never return. We understand. Pit Crew Loyalty ends the one-and-done cycle, turning first visits into lasting, reliable revenue at https://www.pitcrewloyalty.com/ Connect with the Podcast: Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Buy Me a Coffee:https://www.buymeacoffee.com/carm Special episode collections:https://remarkableresults.biz/collections
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Zwith Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numberswith Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcastwith Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitzwith Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communicationwith Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.https://craigoneill.captivate.fm
    • By Hands On
      The emailed me a form to sign up to be a "service provider" The company Service Up will send me the client. They will bill the client and pay me after the repair. Look at some of the highlights from the terms:
       All transactions completed through the Platform are subject to a transaction fee ranging from 1.99% to 10% of the gross amount of each repair, with a baseline marketplace fee of 3.99% unless otherwise specified in a fleet-specific addendum.
      The marketplace fee applicable to a given repair is one of the following:
      • 3.99% (baseline) of the gross amount of all repairs completed through the Platform for all other customers, including customers to whom ServiceUp has referred you.
      • A rate specified in a fleet-specific addendum, which overrides the baseline, provided such rate falls within the 1.99%–10% range stated above.
      In addition to the marketplace fee, the following optional fee may apply:
      • QuickPay fee — an additional 3.50% of the gross amount of the repair if you elect to receive early payment (typically next business day). In the event a credit card is used by the customer for payment, the 3.50% QuickPay fee will be automatically applied.
      So, the fee they charge is any where from 1.99% to 17% if they pay credit card and you want funds next day
      Company reserves the right, in its sole discretion, to modify, increase, decrease, or otherwise change the transaction fees, early payment fees, or any other amounts payable under these Terms at any time.
      But those fees could go up with no notice at all
      The Company shall remit payment to you net of any applicable transaction fees as promptly as practicable after, and contingent upon, Company’s receipt of payment from the applicable fleet customer for the services rendered by you.
      They will pay you for the work you did, as long as they are able to get paid.
      You acknowledge and agree that the Company shall not be responsible for any delays or failure to pay that may be caused by a fleet customer.
      And if the customer fails to pay them, too bad.
      You further acknowledge and agree that (i) the Company may withhold funds in the event of any dispute between you and the Company pending the resolution of such dispute, (ii) you shall not collect any fees for services rendered hereunder directly from a fleet customer and shall receive payment for such services solely from the Company, (iii) in the event the Company determines that you have violated the foregoing subsection (ii), the Company shall have the right to charge a penalty of 10% of the gross value of the applicable services and may withhold that amount from future payments or debit your bank account to recover the penalty and any applicable fees for services.
      AND if they customer fails to pay them and you go directly after the customer yourself, tack on another 10%
      So basically, you fix our cars, and we maybe pay you after we take fees.
      Has anyone used this platform? What do you think?
