Your technician performs an oil change or state inspection and finds a side marker light bulb out.  The CSA gets approval from the customer to replace the bulb.  The technician performs the labor to gain access to the bulb.  The technician finds that water intrusion has caused damage to the socket.  The CSA notifies the customer but the customer declines the service.  Do still charge for the labor portion of the originally approved bulb service as this was already performed but the bulb was not replaced?  Do you not charge anything at all because the issue was not resolved?
This is one of those things you will come to learn through experience.
I charge it, but before you make any decisions let me tell you how is it that I have arrived at my position. -How well do you know this customer? I have learned through experience that a light bulb out, is not always just a burn light bulb. Teach this to your Service Advisors, and techs, although techs should already know this. I learned early on that Mercedes and BMWs would suffer from defective sockets, VW, Fords, whatever. So before you offer and service, make sure you have an idea of what the worse case scenario can be.
So, in this particular case, I would have had the tech check to make sure it was only a bulb that was needed before calling the customer or would have told the customer that a light was out and we didn't if it was a burn bulb, fuse, or socket. That way you would have not surprised the customer if he declined the repair.
So depending how good this customer is, and how well I know them, I would charge them for the install and tell them I would give them a credit when they want return for the complete repair. The point is, you want to keep the customer if he is worth it.
Thanks for the replies Joe and Harry.
To answer Joe's questions:  The vehicle was a new vehicle with low mileage.  The customer suspected that it might be covered under warranty and wanted to take it to the dealer to verify.  It was a first time customer who had no previous work history with our shop.  The job was sold with the assumption that it was the bulb but upon further investigation by the technician, the socket had been damaged due to rain intrusion.  We charged for the bulb service labor but did not charge for the part/bulb itself as this would not have resolved the customer's issue.
To Harry:  How do you typically sell/price a light that has gone out on a vehicle from an oil change/state inspection?  Typically customers want a price before committing to a service and the price could vary based off of all of the different reasons why a light could be out.  We typically sell with the assumption that the bulb itself has gone out unless we can see obvious damage.
5 Star, I don't have to tell you, everything is about communication. Know your customer is not only good policy for the banking industry, it is the same with us. For example, the cashier girl is more price sensitive than the IT engineer guy. So, when you offer a service, leave it open to additional work that may be needed. We do this all the time, " Joe, you have a light out, could be the bulb, but sometimes the connector melts or corrodes, we will check it out, ok." My point is to always manage expectations to provide the best customer experience.
Thanks for the reply Harry.  In that scenario you just mentioned, what do you charge the customer to "check it out"?  Is that service complimentary?  Do you charge for "checking it out" if the customer declines the service once you have told him what he/she needs to fix the issue?
Hmm, I don't follow the question. Are you setting me up? :)
Well, I have to know what's it I am selling, so yeah complementary to check it out. But if I have to diagnose an electrical issue, I give the customer a preliminary estimate before we teardown. Again, know your customer. Keep in mind, there are opportunistic people that will not buy from you, but get anything you give them for free. ( I am sure you know this, but I am being verbose for the young guys that are learning the ropes.)
Edited by HarrytheCarGeek
a word
Like Joe says, there is a lot of gray areas with issues like this in the business.  Like most of the other reply's here, a lot of it has to do with how you present it to the customer.  It's not totally clear from your post, but it sounds like your CSA presented the issue "bulb out"  and the solution "replace bulb" and the cost.  The customer agreed to the "cost" to "solve his issue".  So if the "issue" is not resolved, you cannot fault the customer for not wanting to pay the "cost".  A lot of customer's will understand, but it is not unreasonable for a customer to see this as unfair.  Now, if you state to the customer, "you have a bulb out and we need to start by finding out why, and that will cost x and if it is just a bulb, it will only be x", what you are selling them and what they agree to are very different.  That way there should be no conflict getting paid for it as you should.
Scott
      Thanks to our Partners, NAPA TRACS, Today's Class, KUKUI, and Pit Crew Loyalty Watch Full Video Episode Your posted labor rate may not be the labor rate you're actually collecting, and that gap could be costing your shop thousands of dollars every month.
      In this episode, Carm Capriotto is joined by Andy Adams, a shop owner and business coach, and Rob Sperring, a service manager, to explain why the Effective Labor Rate (ELR) is one of the most overlooked yet impactful performance metrics in the auto repair industry. They break down why ELR falls short, how it affects profitability, and the practical steps every shop owner can take to close the gap.
      What You'll Learn What Effective Labor Rate (ELR) is and why it matters more than your posted door rate. Why healthy shops should collect at least 90 percent of their posted labor rate. How unbilled diagnostic time, underpriced canned jobs, and complimentary inspections reduce profitability. Why excessive discounting, even with good intentions, can quietly erode your bottom line. How shifting consumer buying habits make labor profitability more important than ever. Why improving ELR creates opportunities to increase technician compensation and strengthen your business. How auditing repair orders can uncover missed labor opportunities and unnecessary discounts. Why updating your labor matrix and canned jobs can immediately improve financial performance. How sharing KPI's (key performance indicators) with your team builds ownership and accountability throughout the shop.
      Effective Labor Rate is more than a financial matrix; it's a direct measure of how well your shop captures the value of the work it performs. By understanding where labor revenue is being lost and making intentional operational improvements, shop owners can increase profitability, invest in their teams, and build a stronger, more sustainable business. Rob Sperring, Grand Rapids Motorcar, Grand Rapids, MI Andy Adams, Adams Garage, Terre Haute, IN. Coach at Repair Shop of Tomorrow Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Thanks to our Partner, KUKUI Stop juggling multiple marketing tools. KUKUI’s integrated platform delivers 4x better website conversions, automated follow-up, and real-time ROI tracking. Get industry-leading customer support with KUKUI at https://www.kukui.com/ Thanks to our Partner, Pit Crew Loyalty You’re probably tired of chasing new customers who never return. We understand. Pit Crew Loyalty ends the one-and-done cycle, turning first visits into lasting, reliable revenue at https://www.pitcrewloyalty.com/ Connect with the Podcast: Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Buy Me a Coffee:https://www.buymeacoffee.com/carm Special episode collections:https://remarkableresults.biz/collections
    • By Art Szabo
      I would like to get some static cling personalised oil change stickers from a reliable vendor. I did a search on the web and the amount of suppliers is overwhelming. We have a full color logo and shop information we would like to have on the sticker. The only thing I could find was fifty cents each. Any help would be greatly appreciated.
      Art Szabo
    • By Eurozone_Motors
      Hey guys,
      I recently opened my shop (2 months) I started with autoshop solutions, I got their customer website package and 300 of google adwords per month. The folks over aut AS told me before hand that it woudl take time for the SEO to mature and to start getting results from google etc. Well its been 3 months since the site has been up and I have yet to get ANYTHING from google or the internet in general. When I logged into my control panel and took a look at the keywords they set me up with they were completely unrelated ie. "transmission shop" when I specialize in European makes. Ive searched high and low and have other people search and when looking for bmw, mercedes, audi service Ive gotten as far back as the 9th page with nothing. Has anyone had a similar experience with AS? I have someone who has a proven record of SEO whom a fellow shop owner friend of mine uses and swears by that says he can get me on the 1-2 page in 60 days. Thoughts? I feel like I am throwing away 1100$ a month.
