Going On A Diet - Diet or not, seems truck manufacturers have the same problem I do.
Going on a Diet
“I’ll have two Fords, a Dodge, and one Toyota please. Oh, and I could go for a Cadillac later on.” The more trucks I repair, the more I’m apt to want to do more. One of these days I might have to seriously think about going on a diet. Too much to know, too much to do, and I’m not getting any younger. I’m not sure what they say about old dogs and new tricks is true, but they forgot to mention about adding on pounds slows ya down. However, with cars and trucks, the size changes, the horse power level changes, fuel economy, and luxury items all go through improvements each year. Nothing slows down the advancement of technology, not even a few extra pounds.
In the automotive world, technical and mechanical changes are a constant thing. For me keeping up with those changes is like going to the gym. It’s a constant physical, as well as mental effort that can wear a guy down with all the new stuff he needs to know, the systems variations, and the amount of work needed to get to certain components.
I’m not ashamed to admit that I’ve put on a few pounds over the past 3 decades. I started out as a skinny kid and now, well… ain’t no kid anymore, and I sure ain’t skinny either. But have ya noticed the shape and size of the cars over the years seems to gain weight too? Then, a few years later they’re back on some sort of diet? Model T’s were small compared to the modern car. But, by the time the 40’s and 50’s came along the size of the car had increased. The model T was squarer and boxy looking compared to the more rounded body lines of the cars from the 40’s and 50’s. Well… except for those tail fins, but that’s a whole different story.
The look of the car changed again in the 60’s too! The styles seemed to reflect both rounded and straight designs, and the weight of the average car was a lot less than the older models. Then, by the late 70’s and 80’s car styling was back to the sharp edged crisp body lines, and the cars seemed to be on a different type of diet; this one was more of a fuel economy and emission diet. Of course, I don’t know for sure but, whatever the reason you could certainly tell the difference. Do you remember the Mustang Ghia II? Was that even fair to call it a Mustang? That was one car that wasn’t so much on a diet but more of an anemic excuse for a car.
Seems every decade or so designers and engineers go on some sort of diet and scale back cars to smaller and smaller models, but later on the size and shapes grow again. Along with the size changes, seems nobody can settle on what is a standard, economy, or compact size. What was once a compact size turns into the standard size and the economy car becomes more of a compact. I’ll never figure it all out myself. But, somewhere along the way they give up on the diet and all the designs fatten up again. Just look at the standard pickup over the last few decades.
I used to be able to see over the hoods of most of the standard pickups, heck some of the compacts I could even see over the roof lines too! But now, even what used to be just a small import truck has reached enormous mammoth proportions. Look at the Toyota pickup, it’s twice the size it was just 10 years earlier.
As far as working on trucks, the 60’s through the 80’s models for the most part, I could lean over the fenders and change the plugs or even a belt without having to resort to standing on the upside down milk carton. After putting on a few pounds I find it a bit harder to lean over those fenders, and standing on that shaking milk carton is making me think of going back on my diet again. With some of these bigger and better models, I should think about installing a scaffold and safety harnesses just to get to the air filters.
Some of the truck models have gone from what I would regard as a regular size to a XXXL in size. Then add the big fat tires, jacked up bodies, and you’ve got yourself a street legal monster truck. But jump up there and look under the hood. There’s no room for anything else, it’s jammed packed! If you’ve got anything substantial to do under the hood, such as a headgasket you’re better off just taking the entire cab off and hang it from the lift. Now you’re talking some real “under the hood work”!
So what’s next? Are the engineers going to go back on that diet and start coming up with skinnier, sleeker designs? Or, are they going to keep adding more and more to them until they’re all so huge that the salesman has to bring out a step ladder just so you can go on a test drive? Where’s it all end?
All this getting bigger and better has led to some changes at the repair shop, too. Some shops aren’t equipped to remove the cab of a truck to do some of the service work. It’s kind of a forced diet in a way. But, there are several other reasons shops today have gone to this regimented diet, and it’s not all because of the size either.
One reason for this self-imposed diet is the cost of the various scanning equipment to properly repair these over inflated computers on wheels. Not only are the prices varied, but the monthly/yearly fees to keep that tool up to date is another issue, and as technology advances so does your scanner inventory. Even though the scanner you have now is in perfect working order, the cars that it was designed to service have started to dwindle from the highways.
Technology doesn’t just bring changes for the consumer, but for the mechanic as well. New systems, new ways of doing old things, and new equipment are just a small part of the changes that occur. There seems to always be a newer design that mimics an older system although more stream lined efficiency. Very seldom do things remain the same. The way I’ve got it figured, there’s a mild change every five years and a more dramatic change in technology about every ten years.
The engineers and designers may do what I plan on doing, and that’s go on a diet. But, we all know… most diets don’t last long, and I’ll eventually put all the weight back on that I lost… and then some. If the history of the automotive world is any example of what may come in the future with the next generation of truck designs… the results may end up just like my diet. Go figure…
I might invest into one of those drones so I don't have to climb a ladder to look under the hood on some of these trucks.
Gonzo; If everything is bigger then how do you explain why there is so little room under the hood to work on most vehicles today? Is it bigger there or have they just stuffed 5lbs into a 1 lb bag!
Younger guys have no history to compare a job to, but... Us Old guys sure can.
I can relate with Jeff, as a teenager I would swap intakes and camshafts in my 69 Malibu just for something to do. Engine and tranny came out together with a come along chained to a tree. Blow a motor, no sweat, just buy another junkyard 283/307/327/350/400 bolt on my headers and intake and shove it back in. My Malibu had no a/c, no power steering, no power brakes, no nothing but a pcv valve. I think there was like 10 fuses in the whole car. The most complicated item was the points which I eliminated with a HEI. It wasn't rocket science to fix the thing.
    • By DavisL
      Hey all, Davis here, new to the forum. I built evqualified.com, a free directory that helps EV owners find shops based on verified credentials (ASE certs, EV training, high-voltage safety) instead of reviews or paid ads.
      EV ownership is growing fast and most owners have no idea where to take their car. They don't trust Google reviews to tell them who's actually qualified to work on a 400-800V system. That's the gap this fills.
      If your shop does any EV or hybrid work, even basic stuff like 12V batteries, brake service, tire rotation. You qualify for a listing. Takes 2 minutes to check if you're already on there or submit your shop. Here's the link https://www.evqualified.com/for-shops
      Curious to hear from anyone doing EV work:
      Are you seeing more EV customers coming in?
      What's the biggest challenge with adding EV service to your shop?
      Would a credential-based directory actually help you get more EV business?
      No cost, no catch. Just trying to build something useful for the industry. Again, here's the link to get added to the site https://www.evqualified.com/for-shops.
      Thanks!
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Recorded live at the 2026 TST Big Event, Carm Capriotto sits down with automotive trainer Ken Zanders to discuss the importance of ongoing technical education, building efficient diagnostic processes, and adapting to rapidly evolving vehicle technology. Ken explains why too many shops still rely on a chaotic “grocery list” approach to repairs and how a structured diagnostic strategy can dramatically improve technician efficiency, profitability, and customer trust.
      What You’ll Learn
      Why inefficient diagnostic habits directly reduce technician productivity, shop profitability, and overall earning potential. The importance of following a structured diagnostic workflow instead of guessing and replacing parts. How electronic relative compression testing with a lab scope and amperage probe can reduce diagnostic time from hours to minutes. How modern vehicle technologies like GM’s Vehicle Intelligence Platform (VIP) and Over-The-Air (OTA) updates are changing diagnostics and repair procedures. Why continuous education is no longer optional for automotive professionals working on today’s advanced vehicle systems.
      The biggest takeaway from this episode is that repair shops cannot afford to operate in constant chaos and guesswork. A reactive “grocery list” approach to diagnostics leads to wasted time, unnecessary parts replacement, lower profits, and poor customer outcomes. To succeed in today’s increasingly complex automotive industry, shop owners must create a year-round training strategy that helps technicians diagnose efficiently, think critically, and continuously improve their skills. Structured processes, modern testing methods, and ongoing education are no longer advantages; they are necessities for survival and growth.
      TST Big Event: https://tstseminars.org/
      Ken Zanders, Dorman Training
      Don’t Base Your Success On Probability – Ken Zanders [RR 822]: https://remarkableresults.biz/remarkable-results-radio-podcast/e822/
      Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care
      NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/
      Visit the Website: https://remarkableresults.biz/
      Subscribe on YouTube: https://www.youtube.com/carmcapriotto
      Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/
      Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 Join our Insider List: https://remarkableresults.biz/insider All books mentioned on our podcasts: https://remarkableresults.biz/books Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom Special episode collections: https://remarkableresults.biz/collections Buy Me a Coffee: https://www.buymeacoffee.com/carm   The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                                          Click to go to the Podcast on Remarkable Results Radio
    • By Drivi
      Hey everyone,
      I'm building a tool that helps auto repair shops plan preventive maintenance automatically — it predicts when each customer should come back, sends reminders, and helps keep the shop busy year-round.
      But before I go any further, I’d rather hear it from real shop owners:
      How many hours or bays do you usually have sitting empty every month?
      What percentage of your work is planned maintenance vs emergency jobs?
      Do you use any system right now to remind customers about service? How well does it work?
      What would make you not trust an AI system that claims to schedule customers automatically?
      I’m not here to pitch vaporware — I want to understand how shops actually think about preventive work and downtime.
      If a few of you are curious, I can share a short demo and would love your honest feedback.
      Thanks for sharing your experience — it’s worth way more than any market research report.
