I deal with every situation differently. I do have the technician that worked on it previously repair it correctly. Remember, you will have comebacks, appologize to the customer and take care of the bill. I also give the customer coupons for their troubles. If it is a safety concern that is a comeback and it is our fault and not a defective part, I will give the technician a final warning and tell them if it ever happens again he/she will be fired on the spot. If not, I will give him a warning and deduct his time from the last repair. They will learn very quickly to check and recheck their repairs to make sure it is repaired right the first time.
Comebacks can be a real problem. Finding out the root of it is key. Is the tech making mistakes due to lack of training? Caring? Tools? Workflow management? Is it parts quality?
We all have to understand mistakes can happen. Humans are not perfect. However the way the technician reacts to a possible mistake on their end will speak volumes to their character. If you have a tech that has chronic comeback problem you should have a sit down and try to find the root of it. If a tech is in complete denial and/or wants to blame everyone but himself I would say it maybe time for him to go.
I don't know the exact figure of comebacks but I believe the percentage really should be below the 3% overall mark or even lower on total gross labor sales. Don't quote me on that
We have a plan to keep preventable comebacks at a ZERO percent. #1 verify the complaint. Most important step. #2 make repair including the root cause of the problem, #3 verify the complaint is 100% resolved via extensive test drive. If I'm not absolutely sure the problem is solved the car stays until we can verify we fixed it. "Do it right, do it twice. Three times sometimes" is our motto. An example would be a press in bearing, if it's not perfectly smooth we do it again. Sure, good enough will get the customer out the door for a few months but they will come back displeased when it fails at the most inopportune time. OBDII codes get verified with the readiness monitor setting. Anything else is an educated guess. It takes more time to do it this way but it's better than tying up a bay with nonproductive work.
That said we do get some comebacks due to defective parts, that's a warranty issue not a comeback. I had guys who couldn't make a repair stick, they don't work for me anymore. We are all human, I don't worry too much about minor come backs we just take care of it and away they go. Carelessness is not tolerated.
I can say without a doubt every comeback we have had that was our fault was because I let the customer rush us and we skipped a step outlined above.
We are not currently doing this, and it bothers me. Verifying via readiness monitors is the right way to validate a repair.
Do you keep the car overnight for this? Do you have someone drive the car 5-20mi to set O2's and Cat?
We do a minimum of a 10 mile test drive on every job with the exception of oil changes and tire installs. We rarely deal with comebacks. Most of this is the fact we're a 3 person shop and everyone has personal stakes in our performance. I do all the diagnosis work, so I typically will spend longer verifying my diagnosis and repair because I'm the owner. Hourly or book wages as my motivation! My reputation directly represents my compensation!
For o2 heater to set we keep the car overnight. Evap we can run in the bay 50% of the time. Normal drive cycle takes about 30 minutes. It tunes us in to what else is wrong with the car too. We only do this on diags. We are a 2 person shop, it gets crazy trust me. Tires, alignment, suspension we test drive about 5 miles but our shop is on the highway so its quick. We do state inspections too so it's not unheard of for someone to leave their car a couple days to get it to pass, its pretty much the norm.
Got one back today, didn't follow my own rule. I put an O2 sensor in because the old one was obviously broken. No need for verification, too time consuming I thought and unnecessary. Easy job. Yup I had an hour today though to work on it free when it came back. Had a separate issue but bottom line is the light came back on because I failed to fix every cause of the original cel complaint. In the customers eyes its got the same problem, which is the light on the dash. I'm guilty of stopping when I found a problem, not all the problems.
Comebacks due to negligence are not tolerated. This is how customers are lost. Verify all repairs every time.
Thanks, Alfred. I have been considering hiring a guy to shuttle drive, clean the shop, wash cars, etc. This would be another task to add to his list ... a monitor-readiness drive after every CEL repair. Once we move from 4 techs to 5 this spring, I will pull this trigger.
I've heard some shop owners/techs say that comebacks are Job Security-charge them again for something else. That always made me mad.
I always tried to personally road test the vehicles and confirm a quality job in every case. Most comebacks I have seen is due to short cuts or parts failure. When I could not fight for what was right for my customers I "retired".
The most important thing is to take the customers side when a comeback happens. If they say its broke again I believe them and get the car on the lift asap. 9 times out of 10 something else is broke and its a good opportunity to show n tell at least they aren't mad anymore. No matter what they accuse you of smile and get the car in and look, don't even suggest or speculate anything until its on the lift. The techs ego will chase customers away so be careful. I hate comebacks.
I am super sad right now, we had a customer that we have done a couple winterizations for, a couple repairs, couple more auto starts for came in saying their car was overheating at -40 and she thinks the coolant froze (if so our fault for not getting it rich enough) so we take a look at it and there is no coolant in it because the water pump is leaking on a 2005 tahoe with 145k on it. what does she say? She is going to have to talk to her old tech that she used to have before moving here before doing it because she thinks it might be our fault her water pump failed.
Why at this point are we being questioned.
I would ask how old the water pump and see if I could replace at a deal she could not refuse. Always remind customers that a cooling system is like a chainand any weakness may reveal itself.
My reminder with any cooling system work is. "Now that the cooling system is under proper operating pressure, Watch on system parts for any weaknesses. Other cooling system parts, seals, gaskets that were not replaced today may fail in the future under pressure. The customer should maintain a watch on all fluid levels and dash gauges/warning lights. If in doubt bring car by and we will check all fluid levels at no charge"
This does happen. Some customers are easily discouraged. It sounds like you failed to earn her trust somehow? If she is a multi-vehicle customer, just take car of it to try to earn her trust back, but find out what happened for her to lose your trust. Make sure you emphasize that failures just happen, and it wasn't anyone's fault. Good luck!
      In our episode today, our host Craig O’Neill welcomes founding sponsor and friend, Jeremy Glassco to discuss the potential merits and the root of the desire to step away from devices and “de-smart” with regards to phones.
      Our loyal listeners will remember Jeremy from Communicating With Questions: Jeremy and the Jungle [E006].
      In this conversation Jeremy makes a perfect sounding board for Craig to bounce ideas off of - as he verbalizes some of his own feelings about the ‘Frenetic’ pace of interruptions today.
      We ask:  Is the answer something so dramatic as to retreat from a smart phone entirely?
      One such option out there is a light phone - https://www.thelightphone.com/
      Topics Discussed:
      FOMO - The fear of missing out ….and when FOMO isn’t a bad thing if it saves lives! App apologetics and greater control over communication preferences Disciplined development Disciplined usage
      At the crux of the topic is the dilemma that more efficient communication- which is one goal of technology - usually leads to more opportunities to communicate - which means our social energy is being drained all the time.  What happens when our well runs dry?
      Most importantly - Jeremy and Craig explore what is at the root of the desire to “desmart?”
      Listeners will enjoy hearing take-aways and suggestions to restore balance and minimize distractions with the end goal of being more present - more focused - and simply better for the people we are meeting with.
      Today’s Word of the Day:
      Retention: noun
      the continued possession, use, or control of something.
      Todays Show Post -  Our notes today will be in a different format, written by our host.
      Welcome to another episode of Speak Up - Effective communication.
      Your place for focusing on elevating our communication skills in the auto repair industry - I’m your host Craig O’Neill….
      I want you to ask yourself a question today - each time you receive a notification on one of your devices:
      Do I need this?
      Do I need to do something about this RIGHT NOW?
      This has been my question for any number of the alerts that pop onto my screens on a daily basis. - - As I’ve been at war with distractions in my life.  Loyal listeners have become familiar with my growing concern on the topic and I feel that I’ve begun to find some more balance slowly as of late and will share whats working for me.
      Of note - I’ve been reading a book titled, “Stolen Focus - Why you can’t pay attention and how to think deeply again” by Johann Hari.
      This read was a referral from Carm Capriotto - and it’s worth your attention.
      In our episode today, I have some thoughts on the topic of notifications - and hope to get you thinking differently on what YOU are allowing devices to compromise YOUR focus!
      Our Word of the Day:
      Frenetic: fre·net·ic
      adjective
      fast and energetic in a rather wild and uncontrolled way.
      Listen to this excerpt from the book, Stolen Focus - the author, Johann Hari, writes about a conversation with a friend who was getting notifications for things he didn’t want… and I’ll quote:
      “... All this frenetic digital interruption is “pulling our attention away from our thoughts,” and I think we’re almost in this constant stimulus-driven, stimulus bound environment, moving from one distraction to the next.”  If you don’t remove yourself from that, it will "suppress whatever train of thought you had.”
      That is a quote from Stolen Focus - Why you can’t pay attention and how to think deeply again.”
      The consequences of distractions are real - not just from tasks - but from our creative thoughts and even healthy mindwandering.
      Hari mentions in his book that “a distraction such as looking at an image from a friend pulls the average person away for up to 20 mins!  Not just one!
      And if you look around, you’ll recognize that the distractions are EVERYwhere - and we now have this habitual tendency to scan for them, in our own pockets, and on our own wrists!
      Look around you now - how many people do you see distracted by devices?
      Before you blame yourself or feel bad about this - let me state - our technological world has been engineered this way in a deliberate attempt to get more engagement from us.
      I will say - while I, like all modern humans, struggle with distractions, I have come to develop a few VERY simple and reasonable disciplines regarding notifications.
      I feel sometimes a little old-fashioned on this… but as I discussed recently in episode 35 with Darren Mclea, I feel like I came of age with technology enough to appreciate a slower pace of information than what has been engineered around us now.
      Here we go.  My thoughts for LESS distractions - and being MORE present (be it with your own thoughts - or for the people you are with)
      1.)  Silence your device - I don’t care what tech eco-system you favor - noisy notifications are not just a distraction for you - they are distracting for others.
      2.)  Don’t keep your devices in your pocket at home or work.
      3.)  Disable notifications from all non-essential applications - (or uninstall all non essential applications)
      4.)  No social media notifications.  This doesn’t mean no social media (but more on that another time).  You can check it as you want when you want.
      5.)  Silence that group chat thread…   you know the one.  Texting and group texting… really does function like social media.  Check at intervals.
      6.)   Smart Watches.  Don’t.  This is my opinion but it’s a strong one.  I think one of three things when I see you look at a smart watch while in conversation: 1.)  You have no time for this.  2.)  You have something more important to do.  Or 3.)  This interaction is causing a blood pressure spike.
      7.)  Organize your emails - filter or unsubscribe from ALL non essential emails.
      8.)  Email Away Messages are OK!  (There are conflicting schools of thought on this.)
      9.)  Set Expectations for availability with colleagues and loved ones.
      10.)  Replace the activity with something else - just turning off things on one device will often lead elsewhere.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
