Today we saw a 2000 jeep grand Cherokee in for a overheat. Back story is the customer came in last year (end of last or beginning of this) for a low oil pressure concern. After looking at the vehicle it was found the cooling system was completely chocked full of rust/contamination. Customer states vehicle was low on oil causing low oil pressure, we drained approximately 18 qts of engine oil from the vehicle, the engine oil was actually over the cam. (No oil/water contamination. The vehicle also fails a block test so the head is removed and a blown head gasket is found (visibly blown). we flush the cooling system with vc9 a Ford flush solvent and then follow up with subsequent flushes using bg products. The system had been neglected for a long time and even after the head had been hot dipped and radiator replaced we still had contaminates present but it was much less severe than initially seen. The customer was under time constraints and demanded to complete the flush himself.
Skip forward to last month and the vehicle comes in for a boil overflow. Over flow hose chopped over the fan (looking back I probably wouldn't have accepted a decline on the fan shroud), cooling system and system contaminated again. My first though is blown head gasket or cracked head. Test for combustion gas in cooling system with none present, run vehicle to operating Temps and test drive, return to the shop and no combustion gas in coolant. Cooling system slightly pressurized after test drive but not extreme. However when engine was shut off coolant rushed out into the overflow. Cooling system pressure was watched and operated within range. flushed again and replaced the cap. Fixed all the other small issues and gave it back. Comes back today with combustion gas in coolant and violent expulsion of coolant. Thinking now we've got a cracked head which isn't all that uncommon.
As I mentioned above the head was checked by a machine shop and they were aware of all symptoms present. I was billed for pressure testing, magnaflux and surfacing.
Now I'm prepared to accept partial liability to save face, and looking back I likely would have handled the first job differently. I'm thinking of covering labor (parts store is covering the gasket set) and letting the customer find and pay for the head, or we'll sell a reman with markup. This won't be painful as the job is fairly easy and straight forward and we do quite a few. Honestly the customer (and family) are a little sketchy and the can become verbally agressive and even when given a typical quote are know to go off. They'll accuse you of damaging their vehicle and driving all the gas out, go shop to shop cussing about the last.
My questions are A: how do I word this to the customer to save face and avoid. I'm currently thinking about pointing out the huge discount directly after mentioning the head purchase.
B: should the customer cover coolant and fluid expenses?
C: is it truly a fair deal for the customer that we're paying labor and parts with the exception of the head?
D: cylinder 6 was scored last head removal, should I push for a whole engine job to cover my but and avoid being married to this thing forever?
I've considered the fact that we're not truly to blame here, and that the machine shop missed a crack, or it just occurred, and the warranty is nearly expired. But no more of an issue is it will be for us to handle it I don't see why not help a customer out.
Any advice is greatly appreciated. I've never had any professional service writer training so this forum is extremely valuable!
Unfortunately, the "you touched it, you own it" principle applies here. If you are dealing with a reasonable customer, you should be able to work out a compromise, but it doesn't sound like you are in that situation. Do you want to keep this customer? Will they trash your reputation if they aren't happy with your solution? Most shop owners have had to bite the bullet on similar situations just to make them go away. The problem is knowing when to back away from an ugly vehicle that may have multiple problems, but nothing offends a customer more than telling them you don't want to work on their car. There is no correct answer here. You have to cut your losses and move on to profitable work.
I would install an engine (probably used). You may pour money into a head job again and have similar issues a month later. Install an engine with supplier parts and labor warranty and move on.
This is the reason I try to stay away from head jobs, trans repairs etc...
I just verified it is in fact out of warranty. But I still think I'll cover it. My thought is showing a large discount for labor and the head gasket set, and mention this. Also disclaim that the work is being done outside the warranty period and that the repair was done in good faith and did not offer an additional warranty unless said warranty is offered on cylinder head. I could offer them a credit for the labor and head gasket for labor of the engine replacement. From a customer standpoint how does that sound? My shop is offering my roughly $1000.00 in labor credit, or should I chop it to $500? I'm not so caught up on keeping the customer but I'm pretty caught up on doing the right thing. Pretty rough day, couple warranty jobs that we had no part in the failure lol
Umm why are you offering to pay the labor? They had major issues/neglect when they brought in the first place. It shouldn't have been flushed that much, it should have been replace. Who knows what the block looks like if you had to flush the radiator that much.
Simply tell customer that this is an issue cause by having 18qts installed, a horrible maint schedule, and it sucks, but the correct way to fix it is a remained motor which will be $xxxx.
No reason to bow down and take it in the wallet. These ppl seem to bitch about all their past mechanics, so let them bitch about and and more on to more profitable work.
It should have been a motor from the start with over oiling and rust issues like that. Learn from it. Good luck!
Then they definitely wouldn't have done the work and gone crying to everyone in town lol
Were paying labor because it's a pie job I can knock out in short order and won't even feel it.
Recap Customer neglects engine and blows head gasket.
Customer refuses to let you finish flush.
Customer returns past warranty with possible head damage.
Now you want to warranty the work?
Well since you put it like that lol
Point taken.
I am learning that discount is a dirty word (LOL). I think back to all the times ive caved and offered a discount. I don't want to build a culture of discounts at my shop. We are honest, do great work, and care about our customers. On top of that we spend tons more on training and specialty tools than almost all the shops in the area. I am sure you have the same ethos otherwise you wouldn't be offering a discount however you deserve to be successful and make a good living. Giving into customers that don't do the right thing and put their problems in our laps is not the right way to go about things. Believe me I've had years of experience doing the wrong things!
    • By stevefry
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the Institute Summit, Mike Simard dives into the challenges of recruiting and developing talent, especially in a unique setting like Alaska. He shares his innovative strategy of acquiring lube centers as entry points for new team members and highlights the critical role of strong company culture and leadership. Mike also emphasizes the importance of building the right team, balancing the visionary and integrator roles, and the need to continuously adapt in the ever-evolving automotive industry.
      Mike Simard, Simard Automotive, Alaska
      Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Mike Simard's Background (00:00:00) Acquisition of Lube Centers (00:02:10) Energy and Problem-Solving (00:02:43) Vision for Training Talent (00:03:41) Geographic Logistics (00:05:12) Talent Development and Apprenticeship (00:05:41) Industry Comparison (00:06:32) Recruitment Challenges (00:09:04) Relocation and Recruitment Process (00:12:31) Motivation for Policy Writing (00:16:03) Understanding Unique Selling Points (00:18:05) Building a Strong Team (00:19:20) Learning from Coaches (00:21:52) Delegating Responsibilities (00:22:30) Building Company Culture (00:25:47) Understanding the 'Why' (00:27:09) Finding the Right People (00:28:34) Balancing Inner Voices (00:30:04) Breaking Barriers in the Industry (00:30:35)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
