Is there any recommendations of call centers that can actually handle my service bookings?
I have been struggling with overflow since I started.
Maybe I am selling too cheap.
Friend of me told that AI can nowdays answer but not seen any using these yet. Is that possibility? Googled Vapi today but not really sure yet.
My hardwood flooring buddy created his own AI phone answering. I heard one call and I was AMAZED. It sounded SO real. Pauses and everything. Interesting voice even.
  • 5 months later...
I've been thinking about the missed call problem a lot lately (for reasons I'll get to), and one thing that helped me frame it differently: most shops don't have a call volume problem, they have a call timing problem.
There's already mention of Tekmetric + Auto Ops, which is smart. But the issue those tools expose is usually this: your answer rate looks fine on average, but if you filter by time of day, you'll see 8-10am and 4-6pm are bloodbaths. That's when real customers with real money are calling and they're the ones hitting voicemail.
Consider this quick diagnostic you can run today:
Pull your missed call log for the last 30 days from Auto Ops. Filter for 8-10am and 4-6pm specifically. Count those calls. Multiply by:
  • Your average ticket (let's say $400 for tires/alignments)
  • Estimated conversion rate (30% is conservative, first shop to answer usually gets the job)
That's your monthly revenue leak. Most shops I've talked to are surprised when that number lands north of $3-5K/month+.
The real question then becomes: Is this a staffing problem or a systems problem?
If your service advisors are buried helping in-shop customers during those windows, hiring another body might help but that's $40-50K/year in payroll for what amounts to 2-4 hours of overflow coverage per day. The math doesn't usually work unless you're already turning bays and need the headcount for other reasons.
Alternative approach I've seen work: treat peak call hours like you'd treat peak bay utilization. You wouldn't leave a lift empty during your busiest time. Why leave the phone line empty?
Some shops route overflow to an after-hours service, but most of those can't check inventory or book into your Tekmetric system, so they're just taking messages with extra steps. The callback conversion rate on those is brutal.
Curious what others have tried here, especially if you've solved this without adding full-time headcount. It's one of those problems that feels like it should have a clean answer but most "solutions" I've seen just move the problem around.
2 minutes ago, JustTheBest said:
Just out of curiosity I checked your website. The "Book a Demo" button doesn't work.
Hope this helps!
Matthew
Thank you for that, what's strange is it's working on my end. It goes to a simple google calendar booking page. Perhaps I switch to Calendly..
10 minutes ago, JustTheBest said:
So you know, I see you've got that magic 'pixy-dust-remover'... just tried it again and it's working!
Nice job.
I am tied up right now but going to have a look at a quick call.. I have some clients who may have an interest.
Thanks!
Matthew
Wonderful, it would be great to meet you Matthew and learn about your business as well.
If you want to provide feedback while it still in beta mode; there is a really slick AI advisor with integrated CRM that you can sign up for here. Founding beta testers get a lifetime heavily reduced rate.
Good thread — the "call timing problem vs. call volume problem" framing from CallNous is spot on and worth unpacking further.
From time spent on the service advisor side of the counter: the part that actually hurts isn't the missed call itself. It's that roughly 60% of callers who hit voicemail don't leave a message. They just open Google, call the next shop, and by the time you call back an hour later, that car is already booked somewhere else.
A few things that actually move the needle:
Text opt-in at write-up. Ask customers at check-in: "Can we text you if we miss your call?" You turn a missed call into a text thread instead of a dead end. Follow-up response rates on text are 3-4x higher than a cold callback, partly because the customer already has context from being in your shop.
Set a callback window expectation. Something simple on your Google profile — "We return calls within 2 hours during shop hours." Sounds small but it changes whether a customer waits for you or bounces to the next result.
For any AI or answering service: the one question that matters is whether it can actually book into your shop management system, or just take a message. If it's just taking messages, morning callbacks have near-zero conversion — the customer has already moved on. That's the real deciding factor when evaluating options.
The shift stagger approach is also underrated. First advisor in at 7am, last one out at 6pm covers the obvious peak windows without adding a full-time headcount.
Curious what SMS tools others are using for follow-up — feels like the most underutilized piece of this whole puzzle.
On the SMS tools front — you're spot on that this is underutilized. Most shops I've worked with use one of three approaches:
**Twilio + custom integration** — if you're technical and have time. Full control, but it's work. API integration with TekMetric is possible but requires dev resources.
**Automated SMS platforms** (Textr, SlickText, etc.) — these have shop management system integrations pre-built. They handle the compliance side (TCPA) and have templates ready. Usually $50-150/month. Main downside: callback responses still require manual follow-up unless they're pre-booked in your system.
**The hybrid approach that actually works**: SMS for confirmation/reminder only. Customer calls → you text: "Thanks for reaching out, we got your call. Typical wait is 2 hours. We'll text back shortly." Then the actual booking happens in your system (manual advisor input or AI if you're using that). The text isn't trying to close the deal, it's just keeping the customer engaged while you figure out the actual appointment.
The real blocker most shops hit: SMS alone doesn't solve timing. You still need someone to actually answer or a system that can book. But combined with the callback window expectation (ServiceLane nailed this point), SMS becomes the bridge that keeps customers from bouncing to the next shop.
Curious if anyone here has integrated SMS directly into their shop management system for automated follow-up? That's the missing piece that would actually move the needle.
Noticed almost 6 months too late that I got recommendations from you guys, Thanks and hopefulle these help others in similar situation as I had. Did my own research and went with Agenton and actually pretty much solved my problems.
      Hi, y'all.
      I was wondering if anyone could recommend someone that is producing good quality content for autorepair websites or blogs.
      Harry
      Just wanted to share my experience with broad offer direct mailers (Mudlick Mail) in this case. We have struggled mightily when we were using broad offers (oil change specials) to attract customers. Generally they would be more rude than my normal clients for whatever reason. Question every little charge beyond their $49.95 oil change (full synthetic with brand specific certification). Besides that on average they would be some of the cheapest customers that ever come through our door. I just had one of our last direct mailers go out in March and I guess we are getting some late adopters coming in. When presented with the inspection report, this customer flat out said, "I don't want to put any money into this car!" Ok... When our ARO is above $1000, attracting these types of clients just doesn't work.
      If your business model is to escalate your ARO and work with good clients, broad offers are horrible. Just my .02
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode What does it take to build one of the fastest-growing auto repair businesses while leveraging artificial intelligence to improve performance at every level?
      In this episode, Carm Capriotto welcomes Jesse Jackson, Founder and CEO of Mango Automotive, to discuss how she scaled from zero to eight locations in less than five years. Jesse shares the leadership lessons learned through rapid growth, how custom AI tools are helping improve customer experience and operational consistency, and why she believes it's time to rethink how independent shop owners plan their exit from the industry.
      What You'll Learn How Mango Automotive expanded from a startup to eight locations through strategic acquisitions. The leadership challenges that come with rapid growth and why building a corporate support team became essential. The three cultural principles that drive employee engagement: never yell, bonus well, and have fun. How AI is being used to measure standard operating procedures and improve accountability. Why analyzing phone conversations with AI helps advisors convert more callers into customers. How providing realistic price ranges over the phone can improve appointment conversion rates. How AI-driven follow-up processes dramatically increased maintenance rebooking rates. Practical ways any shop owner can use tools like ChatGPT or Claude to evaluate service advisor performance without spending hours reviewing phone calls. Why thousands of shop owners approaching retirement may be leaving significant business value on the table. How Jesse's cooperative exit model could help independent shop owners achieve substantially higher business valuations than traditional private equity acquisitions.
      Artificial intelligence isn't replacing great leadership; it's making great operators even better. Combined with a strong culture, measurable processes, and innovative thinking about business ownership, AI can help repair shops improve customer experience, scale more effectively, and create greater long-term value for both Jesse Jackson, CEO, Mango Automotive, 8 locations Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/
      Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Special episode collections:https://remarkableresults.biz/collections Buy Me a Coffee:https://www.buymeacoffee.com/carm
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto:Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z:From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numbers: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitz: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communication: Develop Interpersonal and Professional Communication Skills with Craig O'Neill.https://craigoneill.captivate.fm
      A customer that is a Realtor mentioned to me that he is having success using a program called https://calltools.com/ for outbound call marketing.
      I was thinking about doing something like this for this Spring season, has anyone here used an outbound call system of marketing? I have a list of over 80,000 customers and I was thinking it would be a good time to see what results it may bring.
