Hope her problem is fixed. A wreck will cost her more that a brake system replacement in time an money. It's happened to us all. I give the customer options and let them decide.
B)
I had one like that when I worked for a Honda dealership. The customer stated that they had an intermediant problem with the brake pedal going soft. The car was an 06 or 07 Accord. Finally found that Honda had a problem that year with the ABS module sucking air into the system. Just a thought if you look at it again.
Well that's funny because I have a new customer with a similar problem it was at the dealer and had the brakes replaced in shortly after she had an accident. She said the pedal went to the floor
Joe, I would have done exactly what you did. When you can't verify a repair how do you know you've done a repair? Suggestive repairs are the way I handle these situations. But, as soon as another "expert" gets involved the first expert is no longer valid.
If nothing else you could at least show her the price difference between having the dealer make the repair vs. the independent shop. I'd rather lose a customer over things like this rather than deal with the..."I think I fixed it" approach.
Ya can't win them all, and I don't even try anymore. I have to stand behind what I do. If the car does act up again you know she'll call you ...FIRST...then you'll tell her to take it back to the dealer. AND, if the tech is found to have done something wrong...he can just quit and go to the next dealer rather than dealing with it (seen it happen before)...you and me, well... we've got the keys to the front door... we'll be back tomorrow regardless.
