agree
According to the Automotive Aftermarket Suppliers Association report (AASA) for 2012, underperformed vehicle maintenance grew from $54 Billion in 2009 to $62 billion in 2010, a clear indicator that the economy had a definite negative impact on the motoring public and their ability or willingness to perform routine maintenance.
From my personal experience, it has been tougher to sell preventive maintenance the past few years. We have seen an uptick on major breakdowns, but it's hard to sell a preventive major service on a 1998 F150 with 220,000 miles on the clock, especially when they come in on the hook for a failed fuel pump.
There may be an untapped market out there, but consumer's confidence level is low. I am not a supporter of new car dealers, but fresh new vehicles entering the market place should help us down the road. This aging vehicle fleet that was promised to us as our economic savior did not pan out.
That's my opinion, agree or disagree?
The generation that maintained vehicles is graying/dying off. Many people think that a trip thought the fast lube, a stop at the gas station and a drive through the car was is all that is needed. That being said most every car you see on the road needs $200.00 worth of something. The need is great but many customer's are broke. B)
      Bonus Episode - The Impact of Returns, Inventory, & Technology on Auto Parts Pricing with WorldPac
      Thanks to our Partner, NAPA Autotech Training
      Key Points & Takeaways:
      The Problem:
      A 2023 Jeep Grand Cherokee (collision repair) came in with blind spot warning and parking aid malfunction lights on. No functionality in either system post-repair.
      Initial Diagnosis:
      Verified the concern (instrument cluster lit up with warnings). Used an aftermarket scan tool (Snap-on Ultra) and found: ADAS control module had multiple DTCs for open/short circuits on all radar sensors. Parking aid module had similar codes for ultrasonic sensors. Vehicle was hit in the passenger rear, leading to replacement of the bumper, harness, and rear hatch.
      Suspected Causes:
      Blown fuse (common culprit for multiple system failures). Crushed/damaged wiring harness (common after collisions). Module failure due to impact.
      Testing & Findings:
      Checked power and ground at the ADAS module—all good. Inspected wiring harness for damage (no visible issues). Critical Clue: Wire colors didn’t match the schematic. Initially dismissed as a common schematic error. Later realized the entire harness was installed backward (left/right sides flipped).
      The Fix:
      Flipped the harness and radar modules to their correct positions. All codes cleared except two for the blind spot radars—turned out they were also swapped. After correction, all systems worked perfectly.
      Lessons Learned:
      Don’t get stuck in a diagnostic rabbit hole. Good techs pivot when clues don’t add up. Man-made problems can be the trickiest. Always verify previous work (especially after collisions). Wire color discrepancies matter. Even if schematics are often wrong, they can reveal bigger issues. "Slow down to speed up." Rushing leads to wasted time; methodical checks save hours.
      Final Thoughts:
      Awareness is key. Catch yourself when fixating on one theory. Experience can work against you. Stay open to new clues, even if they conflict with past patterns.
      Email Matt: [email protected] Diagnosing the Aftermarket A - Z YouTube Channel Subscribe & Review: Loved this episode? Leave a 5-star review on Apple Podcasts and Spotify
