What do you do to protect your machine? Will stop leak ruin your recovery machine? How to protect it?OTC has a filter I bought it but not sure where to install or if it is recomended.I have a CPS Mach 7 I'm not sure if recover is only from the low side? The machine recovers so slow now I hate to slow it down more........And what if you use a refridgerent identifer to see whats in a customers car and it fails the test .What do you do then? will stop leak or air make it fail ?
  • 2 years later...
I'm going to resurrect this post, as I have been wondering the same thing.
Our equipment supplier has a ton of stories about stop-leak ruining recovery equipment. Are you guys running any pre-filters on your high/low lines, or how are you testing for stop-leak prior to evac'ing systems?
When I worked at the dealer, we never checked... But the type of cars that come into aftermarket/independent shops are probably more likely to have leak sealant vs. those that go to the dealer...
That being said, I said a little prayer right after I bought my AC machine, praying that I wouldn't get any cars in my shop with a sealant... That's how I protect mine :D
They have some kits out there that just screw on the the service port and create a real tiny leak. If the leak stops, then you know it has sealant... Pretty simple system, I can find the website again with a video if ya need
Wow. That's a great idea. Yes, please shoot me the video when you have a minute.
Excellent video. However, he did not answer the million dollar question: What do you do when leakseal is detected? It's certainly not recoverable. Vent it to the atmosphere? Put a filter on the recovery machine (do these even work)? Tell the customer tough luck?
We have used the Neutronic's system for a little over two years now. Have caught more then a half dozen with the sealent in the vehicle system before we hook up. I will not let our guys hook up without testing and if they find any trace they are instructed to not hook up any other A/C equipment,
I would recommend purchasing the tester and using it.
Spence
Thanks, Jeff. Good to know, I'm going to ask the rep about an all-in-one unit.
Spence, how do you service A/C systems where you do find sealants, though?
Wes lets think about it for a minute or two here. Just who do you think would put this sealant crap in?
Haha, they're across the counter from you. The fix-o-can from AutoZone didn't work, so now they're at the shop.
Seems you may have a handle on this... So now the question isssssss... Do you want this kind of person as a customer?
Another part of your comment is more then likely true as well. You say it didn't work, Explain what you mean by it?
Is this a trick questions, because I'm not very good at riddles. The fix-o-can didn't work ... i.e. the leak stop didn't stop the leak / fixed it too late / wasn't the issue in the first place / etc.
Don't mean for it to be a trick question. It was meant to make you think. By answering it you will have come to the conclusion made by your own answers instead of me just saying this is the way it is done. Hell you might not like the way I say it is done and who am I to say something should be done that way in the first place. So if I comment and we discuss it I might turn the light bulb on in your head to a thought of how you want to handle it.
Now to get back to my question. If the leak is not fixed the car probably is low on refrigerant and not cooling as the consumer wants on the hot day they are across your (or my) counter. If it is a leak that is causing it not to work then it will be empty soon and you won't have to recycle it into your machine. There was an "IF" at the beginning of that comment. What does the sealant do? When it works on clogging leaks it will also start clogging up EVAPORATORS and CONDENSERS. If you do not understand A/C systems and are only a shop owner and not a tech then ask your tech what happens if a either or both of these clog up! The system will NOT function properly! Keep that thought for the next paragraph.
I ask you now the same question I did in reply #13. Do you want this person for a customer? Is this a trick question... Well here's some thought.
1. If they are of the cheap kind of customer they are going to eat your lunch if you handle this wrong!
2. If they bought the car this way from a used car lot of private sale you have a chance of making them a customer if you handle it right.
I'll let you dwell on that for a bit... B)
Edited by Spence
Hmmmmm, I've never thought about this type of situation... Can't help but feel you have gone through this before. GRRRRRR, sounds like I need to loosen my grip on my wallet and buy a freaking leak sealant detector kit
Edited by mmotley
Holy cow! All I can say is price shop that neutronics kit!!!! Ebay has quite a few for MUCH cheaper than their website.
Hmmmmm, I've never thought about this type of situation... Can't help but feel you have gone through this before. GRRRRRR, sounds like I need to loosen my grip on my wallet and buy a freaking leak detector kit
Cool so I got you to think. :) So if you have a "CHEAP" consumer... And they installed this crap... For the sake of conversation the leak is a hose... So you drain the half charge left in this system into your equipment, You replace the hose. You did a proper repair and recharge the system with the proper amount of refrigerant but being as the evaperator and/or the condensor is not functioning correctly due to being clogged... This system doesn't cool properly...
Now just who do you think this CHEAP CONSUMER is going to blame for what they feel was a poor service because they now paid for it... Just who do you think they now want fixed for ahhhhhhh... FREE? Oh but you now are back pedaling trying to say they need more parts to fix this vehicle and you want more money...
I said if this is not handled properly they will EAT YOUR LUNCH... Oh yeah and I'm sure they are talking good about you to everyone they know...
How we doing now? B)
Edited by Spence
      EOS One
      Introduction and Sponsors (00:00:01) Overview of the podcast and thanks to sponsors RepairPal and App Fuel. Creating a Shared Vision (00:00:10) Brian discusses the importance of establishing a shared vision for the company. Leadership Team Meetings (00:01:13) Details about offsite leadership meetings and the exercise called "the one thing." Feedback and Growth (00:02:08) Brian reflects on receiving feedback from his leadership team and its impact on personal growth. Shifting Mindset on Growth (00:03:07) Brian shares his fears about growth and how he overcame them to embrace larger ambitions. Disney's Service Model (00:04:17) Comparison of Disney's customer service model to his company's approach to client service. Processes and Procedures (00:05:26) Discussion on the importance of processes in maintaining service quality while growing. Inbound Marketing Strategy (00:07:25) Brian explains the effectiveness of inbound marketing in attracting clients. Outbound Sales Shift (00:09:26) Introduction of outbound sales strategies and the team's initial reactions to the change. Creating a Shared Vision Deep Dive (00:10:34) Brian's focus on developing a shared vision after receiving feedback from his leadership team. Researching Shared Vision (00:11:42) Challenges in finding resources on creating a shared vision and discovering related literature. Book Recommendations (00:12:42) Brian reviews two books on vision creation and his thoughts on their content. Simplicity of Creating Vision (00:13:34) Brian concludes that creating a shared vision is simpler than expected, emphasizing clarity. Vision, Mission, and Values Explained (00:14:45) Brian differentiates between vision, mission, and values with a practical example. Big Dreams and Ambitions (00:15:45)  Brian discusses the importance of dreaming big and outlines a fictional company's ambitious goals. Vision, Mission, and Values (00:16:48)  He explains the significance of having a clear vision, mission, and values for a successful organization. Sponsor Message: RepairPal (00:17:48)  Introduction to RepairPal and its services that help auto repair shops attract tech-savvy customers. Sponsor Message: App Fuel (00:18:48)  Overview of App Fuel's customer loyalty app designed for auto service shops to enhance customer retention. Core Values and Their Importance (00:19:57)  Brian shares his realization of the value of core values in decision-making and company culture. Litmus Testing New Hires (00:20:59)  He describes how to evaluate potential hires against the company's vision, mission, and values. Understanding What You Want (00:21:55)  Brian emphasizes the importance of defining personal and business desires beyond just financial goals. Creating a Clear Vision (00:23:51)  Discussion on the necessity of a detailed, clear vision for a business to guide its direction. Proximity to Your Dreams (00:26:56)  Encouragement to immerse oneself in environments that inspire and reflect personal dreams and aspirations. Crafting Your Vision (00:28:50)  Brian advises on the process of creating a vision, emphasizing the need for time and space away from routine.  The Importance of a Clear Direction (00:29:46)  He compares running a business without a clear vision to aimlessly shooting an arrow, highlighting the risks involved. Creating a Target (00:30:41)  Discusses the importance of having a detailed vision as a target for business goals. Vision Details (00:31:37)  Explains the components of a business vision, including specifics about services and operational metrics. Dream Big (00:34:25)  Encourages thinking big without worrying about how to achieve those goals initially. Historical Example: JFK (00:35:32)  Uses JFK's moon landing vision as an example of effective goal-setting and inspiring leadership. Sharing the Vision (00:37:33)  Stresses the need to communicate the vision clearly to the entire team for buy-in. Selling Down the Ladder (00:38:27)  Describes the process of sharing the vision, starting with leadership and moving downwards. Feedback and Buy-In (00:39:19)  Highlights the importance of receiving feedback and fostering genuine buy-in from team members. Repetition of Vision (00:40:12)  Discusses the necessity of repeatedly communicating the vision to ensure team alignment. Crafting the Vision (00:42:20)  Brian reflects on his personal goal to create a detailed vision for his organization. Importance of Shared Vision (00:43:34)  Concludes with the significance of a shared vision for team alignment and achieving business goals.
