Apparently I am having trouble with pesky power steering issues here in the shop :lol: And parts companies...
apx. 114535 miles
Customer complaint... intermitent hard steering...
Customer has warranty on used vehicle
Replaced power steering pump, pressure hose, blew out return hoses, and replaced steering gear as well.
First p/s pump leaked steady stream through front of pump (replaced again)
Second p/s pump was extremely noisey (replaced again)
Steering gear leaking at pitman arm seal (replaced again)
(Can you tell I'm getting tired of this local parts company????)
As well replaced serpentine belt tensioner... Starting to think I'm working on a Ford at this point...
Customer is still having hard steering issue...
During installation w/ key on engine off... turned steering wheel lock to lock apx 30 times, checked fluid filled as nec... started vehicle briefly, checked fluid, ran vehicle for apx 20 secs... checked fluid again, ran vehicle, turned steering wheel lock to lock apx ten times checked fluid level again.... Road tested vehicle... P/S works well under load and driving conditions... EXCEPT..... AT A STOP SIGN OR LOW SPEED DRIVING virtually no power assist.
My assumption is still air bubbles in lines, or possibly the use of only power steering fluid with no ATF in the mix.... ERRRRR very annoying issue here guys between a run of bad luck on parts, and one of the most simple power steering system designs in production,... I'm breathless at this point. I suggested to my customer to drive the vehicle and put about 50 miles on it to possibly allow the air bubbles to work themselves out, and or to bring it back to the shop in a couple days for further diagnosis (seriously I'm starting to look like the village idiot here in my own head) :unsure:
Does this vehicle have the "speed sensitive steering"? If so, the speed sensor on the steering column is probably going bad.
Edited by DewayneP
I'll look into those things guys, just odd that I'm already on my third pump. I don't have a pressure gauge so I'll start looking for one of those. I also ran across a hydroboost bleeding procedure on Mitchell, I'll give that a try as well. Customer should be coming back into the shop today.
If you haven't done so already you may want to try a different pump manufacturer.
The first TWO were A1 Cardone, the one currently on the vehicle is an AC Delco... all of which are remans... Personally I would have preferred to install a new pump, but working with his "warranty company", they only wanted to pay for a reman of course, and as well expected me to only charge them what my price was on the pump. I hate to turn away work under any circumstance, but as of now I am surely loosing my rear on this one.
If it turns out to be the pump, who pays for that? I know the answer already...
Make sure you go thru that entire system. Start from the basics and don't assume anything.
LOL that's a good one... I'm susposed to get paid twice from A1 Cardone and once more on the gear box... I almost would of been better off getting the parts from Autozone.. HA HA HA... (they're usually good with paying labor at least)...
I have one last trick up my sleeve, I'm going to pull the fitting out of the back of the pump and drill it out to the next size up, and sneak a washer behind the spring... Then head down to my friends shop if that doesn't do the trick and hook up his pressure gauge and see what's going on from there... Funny thing is he's got a 99 silverado he's fighting as well, except I think his is a gear box. (only having problems from one direction on power assist). We may just end up crashing both trucks into each other for fun :lol:
I had one similar to this one a few weeks ago. My father-in-law's 02 GMC 1500 had hard steering turning right only and the left turn was normal. I ended up replacing the steering gear box and the problem was solved. Not a power steering pump issue on the one I had.
Just finally got the truck back to the shop from the customer... Pulling the pump again and drilling the valve out to the next size up, and possibly shimming the spring as well. If not then its off to my friends shop for a pressure test as well... Fingers crossed
As well I don't believe this truck has speed sensitive steering either.
Drilling and shimming the spring and valve didn't help whatsoever... Starting to lean towards another junk A1 Cardone gearbox...OR About to try my luck with an AC Delco/ and or GM Reman... Now for the fun part trying to convince the customer to pay the difference for the "good" parts I originally quoted the job out for, instead of the junk parts the used car warranty company only wanted to pay for...
Lesson for me learned the hard way... It's my way or the highway for now on!
Edited by HTI.WERKSTATT
So far no luck with the third gear box. Has seemed to help a little bit, although only at a complete stop now does it loose power assist. Not sure if this truck actually has hydroboost or not (not to familiar with that system), it does appear to have a p/s fluid cooler in behind the grill, although I did blow out the lines return from pump and return from gear, to clear out any possible obstructions. Even bled the system as if it did possibly have hydroboost just in case. Waiting on a new belt to get here for fun, visibly no cracks, possibly stretched??? If this doesn't do it, I'll have to fold at this point, customer only owes 150.00 at this point, it will be worth it to me to possibly a) loose the 150.00 owed plus a new belt, B) this customer, and get back to work on jobs I've had to turn away due to my rack being tied up, as well as the dealership next door to me. :angry::(
So far got 1200 psi max with valve closed on Kent Moore P/S pressure tester... then 1200psi max on lock to lock both sides... although this is with the wheels up in the air. So far this morning noticed power assist while on gravel at a complete stop... pulled onto concrete and started loosing power assist... I'm not giving up yet! Goanna get this thing off the rack with the pressure tester hooked up until I can drive in lot and duplicate problem yet again and check pressures. Will post up what I find one way or the other...
SPEC IS 1350-1450 PSI... GAUGE COULD EVEN BE OFF 150 PSI.... IF I jack up the front of the truck power assist comes back, it does have after market 20" wheels and tires.. (tires are wider).... going to try oem wheels next??? Thinking that guys run 20-26" wheels all day long and don't have issues is my only concern, and 31-36s... ERRR
does it run ok? plugs and injectors good? Ive seen low power at idle cause accessories to do strange things. If they have oversize tires chances are the did something to "make more power".
At this point, while I was able to duplicate the problem of no power assist with the pressure analyzer hooked up. I still peaked at 1200 psi, as well lock to lock left or right I was peaking at 1200 psi on both sides. I did however jack up the front of the truck slightly until we regained power assist. I'll be putting on my customers factory wheels and tires in the front and trying again... (as the factory tires are apx 3" narrower in width).
As far as any modifications there are none.
As well as far as any suspension problems I have already corrected a loose idler arm (only), and the pitman arm. I can't see any problems with suspension binding up at this point as well.
Curious as to where you have the pressure guage hooked up? If it is directly off of the pump can you move it to the PS box? Perhaps the pressure hose is failing internally?
PROBLEM SOLVED!!!!!!!!!!!
PUT FACTORY WHEELS BACK ON
This is the first time in 11 years that I have ever had an issue with plus sized wheels as far as a power steering issue, what a relief!
That's good to know but what a crap design. GM only designed that with just enough to handle the stock wheels? So much for heavy duty. LOL
      Thanks to our Partners, NAPA TRACS, Today's Class, KUKUI, and Pit Crew Loyalty Watch Full Video Episode What happens when artificial intelligence meets world-class customer hospitality?
      In this episode of Remarkable Results Radio, host Carm Capriotto welcomes Mike DelaCruz, CEO of Overdryve Marketing, and Michelle Tansey, co-founder of Euro Clinic, for a forward-thinking discussion on how auto repair shops can use AI, data, and intentional customer experiences to build stronger businesses.
      From using AI as a strategic business assistant to creating a luxury-level customer journey that rivals brands like Ritz-Carlton and Nordstrom, Mike and Michelle share practical insights on what separates average shops from elite operations. They explain how predictive marketing, operational excellence, and deeply embedded core values can transform customer retention and long-term profitability.
      What You'll Learn How AI can serve as your shop's "big brain" to improve decision-making and uncover blind spots. How predictive marketing can forecast car count, identify customer churn, and improve campaign performance. The concept of the "NASA Shop" and what elite automotive operations do differently. How Euro Clinic creates unforgettable customer experiences through personalized hospitality. The importance of building systems and processes around your shop's core values. Why strong operations must come before marketing success. How small communication changes can dramatically improve customer trust and confidence. The role data plays in making better business decisions and reducing emotional guesswork.
      The future belongs to shops that combine technology with humanity. AI can provide unprecedented insight into customer behavior and business performance, but lasting success still comes from exceptional service, consistent operations, and a culture built around caring for people. The shops that embrace both innovation and hospitality will be the ones that stand out, retain customers, and thrive in the years ahead. Mike DelaCruz, CEO Overdryve Marketing Michelle Tansey, Euro Clinic, Santa Clara, CA. Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Thanks to our Partner, KUKUI Stop juggling multiple marketing tools. KUKUI’s integrated platform delivers 4x better website conversions, automated follow-up, and real-time ROI tracking. Get industry-leading customer support with KUKUI at https://www.kukui.com/ Thanks to our Partner, Pit Crew Loyalty You’re probably tired of chasing new customers who never return. We understand. Pit Crew Loyalty ends the one-and-done cycle, turning first visits into lasting, reliable revenue at https://www.pitcrewloyalty.com/ Connect with the Podcast: Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Buy Me a Coffee:https://www.buymeacoffee.com/carm Special episode collections:https://remarkableresults.biz/collections
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Zwith Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numberswith Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcastwith Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitzwith Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communicationwith Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.https://craigoneill.captivate.fm
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Host Carm Capriotto welcomes Chris Lawson, founder of Technician Find, to discuss one of the biggest challenges facing independent auto repair shops today: finding and keeping great technicians.
      Chris explains why many shop owners fall into what he calls "fire alarm syndrome," waiting until a technician leaves before starting the hiring process. That reactive approach often leads to rushed decisions, poor hires, and ongoing turnover. Instead, he advocates for an "Always Be Recruiting" mindset, where shops continuously build relationships with potential candidates long before they have an opening.
      The conversation explores practical strategies for becoming a destination workplace, creating a recruiting pipeline, and building a culture that attracts top talent in a competitive market.
      What You'll Learn Why reactive hiring creates costly staffing problems How to build a bench of pre-qualified technicians before you need them Why becoming "10-mile famous" can help attract both technicians and customers How culture-focused marketing can outperform traditional help-wanted ads The three things technicians value most: respect, growth, and compensation Why sign-on bonuses often fail and how to structure them more effectively Practical ways to engage passive candidates who are not actively job hunting Resources available through Chris Lawson's free online community for shop owners
      The best time to recruit a technician is before you need one. Shops that continuously market their culture, build relationships with local talent, and maintain a pipeline of qualified candidates are better positioned to grow, avoid staffing emergencies, and create a workplace where top technicians want to stay. Recruiting is no longer an occasional task. It is an ongoing business strategy. Chris Lawson, TechnicianFind.Com Love your shop? Stay, but stay ready. Auto techs join to level up, find good shops, and keep tabs on top indie jobs nationwide. Techs only. No BS. Independent Wrench Jobs: https://www.skool.com/independentwrenchjobs Finding Technicians Part 1- Chris Lawson [RR 803]: https://remarkableresults.biz/remarkable-results-radio-podcast/e803/
      Finding Technicians Part 2 – Chris Lawson [RR 816]: https://remarkableresults.biz/remarkable-results-radio-podcast/e816/
      Technician Attraction Blueprint [RR 921]: https://remarkableresults.biz/remarkable-results-radio-podcast/e921/
      Attract, Develop, and Retain Top Automotive Talent [CC 113]: https://remarkableresults.biz/remarkable-results-radio-podcast/cc113/
      Beyond Babysitters: Developing Strong Managers and Financial Transparency [RR 1076]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1076/
      Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care
      Visit the Website: https://remarkableresults.biz/
      Subscribe on YouTube: https://www.youtube.com/carmcapriotto
      Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/
      Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 Join our Insider List: https://remarkableresults.biz/insider All books mentioned on our podcasts: https://remarkableresults.biz/books Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom Special episode collections: https://remarkableresults.biz/collections Buy Me a Coffee: https://www.buymeacoffee.com/carm   The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                                          Click to go to the Podcast on Remarkable Results Radio
