The model that I am familiar with is a 60% gross profit on loaded tech wages. Loaded would include all taxes, workers comp insurance, benefits like health insurance, dental insurance, vacation pay, holiday pay, training costs, retirement contributions etc.
Thank you!
I would set your labor rate at 3.5x the highest paid tech. So as an example Joe tech makes $20/hr, you should charge $70. I've been using this strategy and it has worked out well. If you are just starting out anticipate what the techs pay will be in 24-36 months and use that figure. You don't want to keep changing your posted labor rate.
Parts gross profit margin (ignoring labor) needs to be close to 50% on average. Your chart above is great. Remember profit margin and markup are different. To achieve 50% GPM you would markup your part 100% or cost x 2.
I use the labor multiplier because it simplifies things, a tech that earns $20/hr probably costs $30/hr when you figure in all the expenses of not only insurance and taxes but soap, gloves, shop supplies, mistakes that cost you money. Its also important to charge for his/her time. The book might call for 1 hour to do a hub bearing, if he's hammering on it for 2 hours charge 2 hours. It seems simple but I hear owners crying all the time they can't make any money.
In the above example say your a nice guy, you charge 1 hour for a bearing and 50% on the part. Its your good customer so you throw him a 10% discount and use a cheap bearing. The part cost you $100, you charge $270 for the job. With the discount you got paid $243. Customer is very pleased. Minus $60 tech cost. Minus $100 for the part. Your shop made $83 on the job, assuming it took 2 hours that's basically an effective rate of $41/hr to pay overhead. If it costs $40/hr to keep the open sign on you made zero for yourself. The bearing fails under warranty 10 months later, customer is shaken up and is angry he paid over $200 and has the same problems. The labor time your not getting back and you also lose 2 additional hours to work on a new job so now it ended up costing you money to do that job. Nice guy 10 months ago is now the bad guy.
Let's revisit that same job. You insist on a OEM bearing or equivalent. $200 cost for the part, 2 hours labor. Now the job is $540. You need to present to the customer some valid reasons to justify charging this amount. It still takes the tech 2 hours. You still kept the open sign lit for 2 hours and paid your counter man. You made $280 or $100/hr money you actually keep*. The chance of failure under warranty is greatly reduced. The customer has long forgotten what he paid to get his car fixed because its still fixed. You are the nice guy now, really.
* after all expenses you might cut this number in half or worse.
Its important to have good percentages, but real money is what pays real bills and earns you a living. Every job needs to be scrutinized to maximize the real dollars earned, don't discount yourself out of business.
  • Like 7
We begin our estimating process by looking up the times in the national labor guide as published in our Mitchell software. The settings automatically bump the charged time by 33%. We setup a default that automatically assigns every generated labor line to a tech named Tech Assign. (It shows up as Assign, Tech) and that technician assigns costs to the job (as alfredauto suggested) by a calulation based off our highest paid technician's loaded payroll cost. We actually use a bump in that calculation also which helps to protect our bottom line against a techncian who is less than efficient on any particular job.
So, by this explanation, a job that takes 2.5 hours according to the guide (with all combinations & consideration for any overlapping service), is charged to the customer at 3.33 hours. Here's what happens:
Let's say that Joe, our highest paid technician, earns $23 per hour, flat rate. So of course, Joe's rate in the technican's setup screen indicates that he will cost $29.90 per billed labor hour with estimated taxes, workers' comp fees, etc. added in. The default technician, "Assign Tech" is also setup this way. The software suggests charging the customer 3.33 hours, or the amount of time in the guide multiplied by 133%. The default tech is given 2.5 pay hours, the customer is charged 3.33. Once the job is assigned, no matter which technician is paid for the job, the nature of the profit margin as it pertains to the associated labor costs can't change in a manner as to cause us to lose money on the job. In fact, if it's ultimately assigned to a tech that earns $17 flat rate (or $22.10 loaded), the additional $25.97 collected in labor fees is essentially unassigned, and bolsters the profit margin originally written in the estimate. Fair? Absolutely! If a less experienced tech is assigned a job, and has any struggles with it, our more senior staff is always happy to help, even for a few minutes to help get them past a difficult point, because the company can generously afford to pay that tech the additional time, ON TOP of what the assigned tech is earning, because it's a built-in contingency.
It also gives us a very powerful advantage...ANYtime one of our technicians runs into a problem on a job that was unforseen, or requires additional effort or steps to complete the work, our staff can, at their discretion, request additional time on a job, and given that our effective labor rate weekly is generally higher than our posted rate (due to all the calculations above) we can almost ALWAYS give that time generously to our staff and encourage them to continue to do the best they can, taking their time, and not cutting any corners...without going back to the customer for more time/money.
Our parts matrix is a simpler assessment. We generally try to get a 100% markup or greater, representing a 50-60% profit margin on the parts. Now of course, in all fairness to our customers, we can't rely on the software to tell us what to charge without first assessing a completed estimate and diligently making sure the total estimated cost represents a fair price. Anytime there's any question about whether our price is competitive, our service advisors are encouraged (BEFORE presenting the estimate to the customer) to check some of the various publicly available resources such as AutoMD, or RepairPal to see how we size up. All in all, we tend to average a gross profit margin of between 60-64% on the written estimates weekly.
We've learned that it's a MUCH better proposition to charge much more than the discount/hack shops, and only nominally more than the reputable shop. In any given set of circumstances, it frees us up to always be ready and willing to give back to our customers when it's truly warranted, or even toss in some free, ancillary services on the visit, or on repeat visits.
Just one man's opinion.
stowintegrity, how do you tech pay rate compare to your posted hourly? I like your idea however I feel that you would have to be working with a lower posted hourly to justify a 33% matrix markup on your labor rate to stay competitive with automd and repairpal quotes.
The lowest profit margin on one hour of labor, with the bump, as I called it, is about 70%, as our posted discount rate is $80. The important factor, though, is that while we answer the question regarding what our "rate" is freely, we don't sell hours, or time. Heck...sometimes it feels like we don't even sell parts...we sell solutions to problems.
Here's a completely hypothetical situation: If the going rate for a brake job in town is $150, and the range indicated on Repairpal is between $120 and $200, anything inside of that range is understandable. However, what if I told you (up front) that in order for us to do that job, we would have to charge $250, that the parts are all warrantied for 3 years, 36,000 miles, and that although it will take a day or so to finish it, we can offer you a brand new 2015 car to drive for the day at no additional charge, and this service package comes with a gift card for lunch at Subway? I'm making this up, of course, but my point is that price is truly only ONE consideration as to why they should do business with you. Instead of figuring out how to come down to "match" the competition's pricing...figure out how to stand up, and offer more to your customers. You'll build loyalty that your competitors will be unable to infiltrate/steal.
We offer one of the most valuable selling propostiions in our market, founded on the way our customers are treated, and are continuing to seek out over-the-top methods of earning their continued loyalty. I know I'm off topic now, but pricing, service, & offering...it's all connected. If they want a cheap price, I smile, shake their hand, and promise them that if they look around, I know they'll find it. It's a beautiful thing when you can know your intended market so well that it becomes easy to identify when someone you're trying to help just doesn't fit the mold. Stop wasting time & money worrying about trying to fit square pegs into round holes. It's expensive, frustrating, and not as profitable. The ONLY time it's more profitable to approach this any differently is if you happen to be the cost/price leader in town. And even if you are, it's a fragile mountain of gold you're sitting on.
Thanks for your post. I agree with you in terms of offering value other than price in considerstion for our services. We are almost always higher than the highest "average" estimate according to repairpal. My question to you was directed to how you justify keeping up with a 70% profit margin in ratio to tech pay. My labor rate currently is 116.97 however I will be bumping it up to 119.97 to keep up with offering my technicians competitive pay while keeping our margins. I like the idea of using a multiplicative for the customer rate while keeping the "posted" rate competitive. I will have to do some math with my numbers.
I'm not sure what you mean, I'm sorry, (but I think you & I are in agreement) Instead of starting with considering what a job may cost anywhere else, our process is reverse engineered, in a sense. Determine what you want to pay your highest paid technician, then work the math backward to determine what you'll need to charge to get the margin you need. Comparing it to publicly available averages or other data is just the furtherst attempt we try to make to make certain we're being as competitive as we can. My bottom line pricing to my customers is justified by clearly stating what value they get for the services I propose. My technicians? I justify what I pay THEM, based on performance, experiences, and talent. As for the ratio between the two, I've made it no one's business but my own. (And all of you nice people, lol)
If your labor rate is $117, you should be able to pay your top technician as much as $33 an hour, loaded, and still keep your margins healthy, according to my application of this system. The truth lies in the simplicity of this: Profit is not a dirty word. Customers and technicians alike are universally important to my success, of course. But I further justify the ratio to both groups by letting them know that there are more bills to pay than just labor & parts. IF I can't profit according to my business' needs, I can't stay afloat...and then I'm of no service to ANYONE.
You sound like you have a firm grasp on this, I'd like to hear how your proposed labor change helps your numbers!
Tony
He's asking the following:
If your highest tech is paid $30/hr, and your posted rate is $100/hr, you're making 70% GP on labour.
Now when you estimate jobs, you multiply the labour guide hours by 1.33, essentially charging $133/hr on the labour guide's hours.
This is now 77.5% GP on labour vs the industry standard 70%.
If your customers are willing to pay this, great! However, compared to other shops your estimates will end up being very high, especially on long/labour intensive jobs.
Have you reduced your original 70% GP to compensate for this (maybe posting $80 or $90/hr on a $30 labour rate) so your estimates aren't really high?
Like mspec, I also like the idea of using a multiplier on the labour guide, but I feel that 10-15% might be a lot more reasonable to keep your estimates within range of other shops instead of 33%?
I see your point. I guess what's worked for us so far has been that although we use the process I've been describing to write our estimates, that in the end, I guess we do, in fact, adjust the labor $ our POS assigns if we feel the job hasn't been written in such a way as to still be able to justify the price over the value our customers are receiving.
It makes me wonder what mistake is made more often? Do more shops tend to undercharge, either fearfully or thinking that a low price is the best way to generate volume, or do you think there are more that error on the side of setting price too high, ignoring the value propostiion as perceived by those they hope to serve?
I guess I really, truly want to know that we're charging what we must in order to be highly profitable, but not so much that our customers try to lump us in with the less-than-reputable shops that price-gouge.
I'm not certain where I first heard it, but we've made it part of our service writer training to ask the following question: "When considering parts/labor costs passed on to our customers, how much should you charge?" The simple answer is to let the trainee know that on every estimate they should charge systematically AS MUCH as they can, minus JUST ENOUGH to make absolutely certain that our customers can't help but see the value in the offering, and are delighted to write the check.
This is as good as anywhere to ask the question: When considering ONLY the parts/labor equation...what is your shop's weekly goal for gross profit margin? In considering a week's worth of service completed, what's the lowest and highest acceptable margin? (Assuming you'd rather not have a service writer try to write all your service at 95% GPM, giving you a bad reputation for being overpriced)
Curious.
    • By brian61
      Thanks to our Partners, NAPA TRACS, Today's Class, KUKUI, and Pit Crew Loyalty Watch Full Video Episode Your posted labor rate may not be the labor rate you're actually collecting, and that gap could be costing your shop thousands of dollars every month.
      In this episode, Carm Capriotto is joined by Andy Adams, a shop owner and business coach, and Rob Sperring, a service manager, to explain why the Effective Labor Rate (ELR) is one of the most overlooked yet impactful performance metrics in the auto repair industry. They break down why ELR falls short, how it affects profitability, and the practical steps every shop owner can take to close the gap.
      What You'll Learn What Effective Labor Rate (ELR) is and why it matters more than your posted door rate. Why healthy shops should collect at least 90 percent of their posted labor rate. How unbilled diagnostic time, underpriced canned jobs, and complimentary inspections reduce profitability. Why excessive discounting, even with good intentions, can quietly erode your bottom line. How shifting consumer buying habits make labor profitability more important than ever. Why improving ELR creates opportunities to increase technician compensation and strengthen your business. How auditing repair orders can uncover missed labor opportunities and unnecessary discounts. Why updating your labor matrix and canned jobs can immediately improve financial performance. How sharing KPI's (key performance indicators) with your team builds ownership and accountability throughout the shop.
      Effective Labor Rate is more than a financial matrix; it's a direct measure of how well your shop captures the value of the work it performs. By understanding where labor revenue is being lost and making intentional operational improvements, shop owners can increase profitability, invest in their teams, and build a stronger, more sustainable business. Rob Sperring, Grand Rapids Motorcar, Grand Rapids, MI Andy Adams, Adams Garage, Terre Haute, IN. Coach at Repair Shop of Tomorrow Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Thanks to our Partner, KUKUI Stop juggling multiple marketing tools. KUKUI’s integrated platform delivers 4x better website conversions, automated follow-up, and real-time ROI tracking. Get industry-leading customer support with KUKUI at https://www.kukui.com/ Thanks to our Partner, Pit Crew Loyalty You’re probably tired of chasing new customers who never return. We understand. Pit Crew Loyalty ends the one-and-done cycle, turning first visits into lasting, reliable revenue at https://www.pitcrewloyalty.com/ Connect with the Podcast: Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Buy Me a Coffee:https://www.buymeacoffee.com/carm Special episode collections:https://remarkableresults.biz/collections
    • By tirengolf
      I was looking for some input into advertising. I have really not done any the last 25 years. We are rebranding or should I say changing directions a little. Going back to tires, brakes ,alignment and maintence. When I did it last other than the phone book we did a little newspaper. I think those have basically gone. So many options out there, I just do not want to throw a bunch of money away on the wrong advertising. Any help would surely be appreciated. Sincerely David
    • By Michal
      Hi everyone,
      I’m a technical founder working on a new tool for repair shops. The idea is simple: many shops lose revenue because missed calls = missed jobs. We’ve built an AI voice agent that can answer when the shop is busy, ask about the car and the problem, schedule appointment and pass a ready note to the team (with vehicle info, sometimes even VIN). The next step is connecting it with parts suppliers so shops can order before the car even arrives.
      What I’m missing is not the tech, but someone from inside the industry:
      who knows the daily pain of running a shop,
      has connections with other owners,
      and could take the business side (validation, first deals, partnerships).
      I’m not looking to sell a product here. What I need is a partner (or at least early testers) who wants to try something new and help shape it.
      If this resonates, please DM me or reply here.
      Thanks, Michal
    • By Transmission Repair
      Covering The Cost Of Marketing
      After quite a few years in business I learned the inverse of the rule that a business's price should cover all costs.  Early on, whenever I considered something new, or something that would make my job easier, or improve business, I would often think "I can't afford that."
      After a number of years in business, I slowly learned I could afford any of those things as long as I raised my pricing structure to cover those new costs to doing business.  I soon learned very few people were giving me price objections when closing sales at a newer, higher price.  I felt good about my prices because I knew they were rightfully justified and not some willy-nilly price increase.
      This was especially true when considering any new technology for your shop.  What once was considered as a luxury item is now very essential.  Shop Management Systems, Digital Inspection, and Text Messaging soon became our industry's norm.  Soon, I proved to myself that SEM (paid Search Engine Marketing) coupled with call tracking was just as essential.  SEM is sometimes referred to as Pay-Per-Click (PPP).  Here's a little history...
      Our annual sales at our transmission shop had plateaued at $700K before SEM and call tracking.  Cautiously, we dipped our toe into SEM at first.  Later, we tried call tracking with only 10 phone numbers.  Combined, we were spending about $1K/mo. and we saw an $8K/mo. increase in business.  To make a long story short, I came to learn the more I spent, the more our sales grew.
      Eventually, we were spending a combined $5K/mo. on SEM and call tracking with 100 phone numbers.  I have to explain why so many phone numbers.  Ninety-two of those numbers were in a "phone pool" with a 10-day cookie attached.  Whenever somebody did a search for anything transmission-related, they would have one of those numbers attached and display on our website.  Each different search would get a different number out of the phone pool shown on our website.  It would take too long to explain the technology but let it suffice to say that the call tracking company handled it all with a couple of lines of JavaScript added to our home webpage. After 10 days, the cooking would expire and go back into the Phone Pool to be used for another search.  The rest was all done behind the scenes on their servers.
      It seemed to me, the more I spent, the more sales went up.  I leveled out at $5K/mo. only because of the limited size of our Salt Lake City area market.  We appeared on every search and the very top listing on most searches, if we weren't at #2.  I learned there were only about 1,300 transmission-related searches per week.  I couldn't pay any more simply because there weren't any more clicks to be had.  In the course of a year, our sales went up from $700K/yr. to $1.2M/yr. which is a $500K increase for less than a $60K/yr. investment.
      During this year of learning and growing, I slowly raised our prices to cover the new increased cost of doing business.  In my mind, I wasn't paying for it out of my pocket, my customers were paying for it.  It worked out to cost 12% of the $500K/yr. increase in business or 5% of the $1.2M/yr. in total sales.  I ended up raising our overall parts & labor prices about 8%.  Nobody even flinched, let alone complained.
      I think this sort of mindset when considering any new technology should be the norm.  I don't know of a shop that doesn't try to cover its' cost of doing business.  Just consider raising your prices to cover any new tool, equipment, or technology.
      In my next post, I'll talk more about SEM and call tracking.
