There's a new wrench in town
A Volkswagen Beetle was left in the parking lot one cold morning. It was one of my regular customers 01' Beetle. All I knew of the problem was that it wouldn't start.
"Let's check a few things first," I said. I pulled out one of the glow plugs to check it for wear and tear and if it was getting the necessary voltage to warm it up. All was well; in fact they looked fairly new. I had a meter handy so I checked to see if the resistance was correct…right on the money. I cracked open a fuel line to one of the injectors … no fuel…. No fuel??? Hey, wait a minute… isn't that kinda necessary?? The tank was full, but no fuel pressure at the lines. One of the things to worry about with a diesel is … air in the fuel lines…. Anytime these engines get any air in the fuel lines… oops… they will be hard to start or not start at all. Ask anyone with a diesel that has ran out of fuel…ask them how long it took to get it started again.
Well, before I start tearing into other possibilities, this would be a good time to shoot a little starting fluid down its throat and see if I can get a burp or two out of the little engine. I want to be sure there are no "mechanical" issues with the engine.
A couple of quick shots of ether and crank of the key…. Shazaam…!! Started right up…. Hold on hold on…. fuel is spurting everywhere.. Shut it off... Shut it OFF now!! Looking under the fuel distributor you could see that the fuel was actually coming out of the two halves of the distributor… apparently the gasket or housing to the distributor has developed a major leak. My guess would be probably from the cold. Air was getting into the fuel lines, but once the engine spun fast enough to overcome the air rushing in from the bad distributor it then was able to start.
I called the customer and gave him the bad news, the biggest problem was cost; a fuel distributor isn't a cheap part by any means. Luckily for the owner he was still covered under the factory 100k mile warranty, but barely. It was about 500 miles shy of going over the mileage. The obvious next step would be to have the car towed to the dealership. All the work could be completed under the warranty and save the customer from a huge repair bill. Nothing like a warranty when it actually pays off on an expensive part… I'm actually more relieved myself. It's not the easiest job by any means, oh I'll do it… but given a choice between changing a fuel distributor or taking a swift kick …. I'll take the swift kick.
At this point I'm through; I did my part, diagnosed the problem and sent it on to the proper repair facility to have it done. What more should I do? Then the phone rang, it's the owner of the car.
He was quite calm on the phone.. I couldn't believe what he was telling me.
In a very calm and collective voice the owner said, "The tech at the dealer says it needs new glow plugs, new glow plug relay, and a new glow plug harness."
Once the initial shock wore off, I began to laugh. "You're kidding me," I answered laughing the whole time.
"No, that's what the man said," he said, with a little smirk in his voice.
I think he knew, but didn't want to say anything to me about what he thought was going on… oh, I knew, I knew quite well what was going on.
He asked, "Do you want to call them?"
"No, let's see if they want to call me. I already know what's wrong with the car. Let's try this; ask them if they will guarantee the repair and make it right if that doesn't fix the problem," I told him.
"Ok," said my now laughing owner, "This ought to be a fun adventure. I'll play along with ya."
The phone rings again… it's the tech from the dealer. I felt like it was one of those old western movies. You know the ones, where the bad guy strolls into the bar and says to the other cowboy, "This here town ain't big enough for the both us." Oh yea, my young, wet behind the ears dealer tech had something to prove. You could tell he had been shining his wrenches for just an occasion to show up an independent shop. I could hear that "western" movie music in the background. I was waiting for the "call out" any minute now. It's the old "I'm the dealer tech and nobody knows more than me." You know, I'm getting older, I may not be as fast as I use to be… but it's still going to take more wrench than this spark plug has to get the best of this old gear head. Talk about a cocky, fresh out of diapers, full of himself dipstick. If this guy would just listen to what he was saying, he could have figured out who the real cracked engine blockhead was. I'll bet he goes to work; dons his dealership uniform and transforms himself into tat ta tat da…. SUPER MECHANIC!! Look in the shop, springing from tool box to tool box, no, could it be… why yes it's SUPER MECHANIC..! I'm honored to be in the presence of such a marvel of the auto world. Could I have finally met my match, am I to be put down at high noon like the Wild West gun slingers of old? Hold on there, partner, I still have my secret decoder ring and my x-ray glasses to ward off such attempts of super human abilities. I'll call you out… High Noon, wrenches ready… let's do this cowboy.
He proceeded to tell me that he had a code for an intermittent glow plug signal and that they had records showing that the glow plugs were changed at the dealership 2 years ago. Naturally, that was what was wrong with it. He didn't need another shop to tell him that, because he was perfectly capable of handling the repair and that the only reason he was making this call is because it was company policy to verify complaints if the customer didn't agree with their diagnosis. Holy Wrenches Hombres, at least we have that going for us…
You know, there are times I'd just like to give these snot nose, green horn, socket jockeys a quick thwack on the noggin. But, this kid was lucky, I wasn't in the mood to belch out my usual "you're too young kid, you're going to need a little more grease in the right places before ya go messin' with this old wrench" speech. Instead, I was going to give him another chance to rethink his diagnosis.
"How did you arrive at that conclusion," I asked.
"I had a code for it, and these cars have a history of problems with the glow plugs," he very proudly stated.
"Did you check the glow plug themselves?" I very calmly asked.
"Well, they were changed 2 years ago," he answered.
First mistake; more to follow.
"Let me get this straight, you found a code, you didn't check it, and now you want to change the part… is that it?" I said in a stern manner.
"I don't need to check it, I already know," he quickly bantered back.
"I hate tell you this, but that code is there because of me. I pulled the glow plug out and hand checked it. I even checked the resistance value on the glow plug and the incoming voltage. I didn't see a thing wrong with the glow plug circuit. Did you by chance notice the raw fuel under the fuel distributor?" I asked in a even more stern voice.
"Yea, I saw the fuel. I washed it off." he answered in a confident manner, "It started to stink up the shop and blow the fumes all over the shop. The car was directly under the shop heater and the other techs were complaining. Not like it had anything to do with the repair anyway. You guys' are just a little sloppy, you should clean up things better next time."
"That fuel you seen is from the fuel distributor housing," I told him.
"Oh, you know, all these customers are all alike; they're just trying to get stuff done for nothing while it's still under the warranty. So, it's no big deal," he answered.
Oh please, don't tell me this kid had the nerve to say that. It reminds me of all those comments that small children say to strangers in a crowded room. Usually out of context and never under the right circumstances and, most often, with their parents standing right there totally embarrassed by the whole thing.
Another mistake, keep going kid… it's just keeps getting better.
"I think you should put this car back outside and check it in the morning after it gets good and cold. It's going to leak again, that I'm sure of." I told the new wrench.
"I'm going to have to ask my service writer about that, because I'm very sure of the repair work that I have already diagnosed. So, like I said... This is just a courtesy call... not a call to tell me how to fix it." He said in a very demanding tone.
"Ok fella, have it your way. I'm just trying to help you out. I didn't spill a drop of fuel. That fuel you see came from the distributor not from anything else." I said, trying to get my point across.
"I understand, but you know, here at the dealership we have the most sophisticated equipment and can diagnose these problems better and quicker than you can." He answered.
The mistakes keep adding up. About now I'm shining my wrenches for a showdown… somebody is going to get it, and it ain't me.
I think if I were him, I would be concerned that the glow plugs that were installed 2 years ago have failed again, seems pretty odd to me that the glow plugs wore out that quickly. But this young wrench head is strictly going by the code and not diagnosing the problem.
I told him, "Wouldn't it be proper procedure to clear the code and then recheck. Chances are it was a false code do to the fact I had disconnected it earlier."
He didn't seem to be interested in my comments. As I expected, the dealership called the owner and told him that they were going to do "further" testing.
The next day the owner called me back again with even more astonishing news. "The dealer tech said that the raw fuel was from the glow plug that you took out," the owner said laughingly. I figured the tech was trying to cover his tracks.
A week later the little 01 Volkswagen had a new fuel distributor and a happy owner. All under warranty, and it didn't need those new glow plugs replaced… imagine that.
This tech at the dealership was just a young wrench with a chip on his shoulder. Trying to out wrench an old hand like myself was not a smart move. To top it off, the owner isn't dumb about the whole thing either. A few more years under this young techs' toolbox and he might just make it.
I guess you could say that there was a showdown at high noon. Holster those wrenches boy, you've got some more miles to put under the hood before you'll be ready for another showdown.
I think it was a good lesson for the young ratchet head. Just because you're dealing with an independent shop doesn't mean they don't know how to use those wrenches. So saddle up there youngster, I'm proud of ya, this was a good lesson for future endeavors. For me, the trigger finger is a little slower than it used to be… But I can still tell the stories… one wrench at a time.
Edited by Gonzo
      Episode 271 - Training New Techs & Building a Lasting Automotive Business With Charles Mitchell
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Host Carm Capriotto speaks with Jay Goninen, co-founder and president of WrenchWay, about insights from the 2026 Voice of the Technician Survey and what it reveals about the state of the automotive workforce.
      Jay encourages shop owners to download the free report to uncover blind spots and start meaningful conversations with their teams. The data show that technicians strongly prefer a four-day, 10-hour workweek with no weekends, along with proper equipment, paid vacation, retirement benefits, and paid training.
      While dealership technicians made up a larger share of respondents, independents stood out in workplace culture. 63% of independent technicians would recommend their shop to a friend, compared to 36% at dealerships, though dealerships scored higher in providing paid training. Across both groups, technicians favor an hourly wage plus bonus structure, which many feel better supports diagnosticians than traditional flat-rate systems.
      The discussion also highlights a troubling trend: the industry’s Net Promoter Score dropped to -60 in 2026, signaling that many technicians would not recommend the profession to others.
      To strengthen the talent pipeline, Jay discusses ASE Connects, a new initiative aimed at connecting shops with high school and technical school automotive programs to support them through mentorship, advisory roles, and community engagement.
      Carm also advocates elevating the profession by shifting the language from “mechanic” or “technician” to “specialist,” emphasizing the expertise required to work on today’s vehicles.
      Overall, the episode serves as a wake-up call for shop owners to use the survey insights to evaluate their culture, communication, and work environments, and to become employers technicians are proud to recommend.
      https://wrenchway.com/resources/2026-voice-of-technician-survey-report/
      Jay Goninen, Co-Founder and President, WrenchWay
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Connect with the Podcast: - Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ - Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters - Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 - Subscribe on YouTube: https://www.youtube.com/carmcapriotto - Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ - Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ - Visit the Website: https://remarkableresults.biz/ - Join our Insider List: https://remarkableresults.biz/insider - All books mentioned on our podcasts: https://remarkableresults.biz/books - Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom - Buy Me a Coffee: https://www.buymeacoffee.com/carm - Special episode collections: https://remarkableresults.biz/collections - The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ - Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ - Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ - Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ - The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ - The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ - Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                         Click to go to the Podcast on Remarkable Results Radio
    • By Hands On
      The emailed me a form to sign up to be a "service provider" The company Service Up will send me the client. They will bill the client and pay me after the repair. Look at some of the highlights from the terms:
       All transactions completed through the Platform are subject to a transaction fee ranging from 1.99% to 10% of the gross amount of each repair, with a baseline marketplace fee of 3.99% unless otherwise specified in a fleet-specific addendum.
      The marketplace fee applicable to a given repair is one of the following:
      • 3.99% (baseline) of the gross amount of all repairs completed through the Platform for all other customers, including customers to whom ServiceUp has referred you.
      • A rate specified in a fleet-specific addendum, which overrides the baseline, provided such rate falls within the 1.99%–10% range stated above.
      In addition to the marketplace fee, the following optional fee may apply:
      • QuickPay fee — an additional 3.50% of the gross amount of the repair if you elect to receive early payment (typically next business day). In the event a credit card is used by the customer for payment, the 3.50% QuickPay fee will be automatically applied.
      So, the fee they charge is any where from 1.99% to 17% if they pay credit card and you want funds next day
      Company reserves the right, in its sole discretion, to modify, increase, decrease, or otherwise change the transaction fees, early payment fees, or any other amounts payable under these Terms at any time.
      But those fees could go up with no notice at all
      The Company shall remit payment to you net of any applicable transaction fees as promptly as practicable after, and contingent upon, Company’s receipt of payment from the applicable fleet customer for the services rendered by you.
      They will pay you for the work you did, as long as they are able to get paid.
      You acknowledge and agree that the Company shall not be responsible for any delays or failure to pay that may be caused by a fleet customer.
      And if the customer fails to pay them, too bad.
      You further acknowledge and agree that (i) the Company may withhold funds in the event of any dispute between you and the Company pending the resolution of such dispute, (ii) you shall not collect any fees for services rendered hereunder directly from a fleet customer and shall receive payment for such services solely from the Company, (iii) in the event the Company determines that you have violated the foregoing subsection (ii), the Company shall have the right to charge a penalty of 10% of the gross value of the applicable services and may withhold that amount from future payments or debit your bank account to recover the penalty and any applicable fees for services.
      AND if they customer fails to pay them and you go directly after the customer yourself, tack on another 10%
      So basically, you fix our cars, and we maybe pay you after we take fees.
      Has anyone used this platform? What do you think?
      Why Technician Pay Isn’t the Real Problem
