Something I see in almost every independent shop I've worked with: a car pulls in Monday morning, and it doesn't get touched until Wednesday afternoon. Not because the tech was busy — because nobody had a clear handoff system.
After 20+ years working with shop operations, here are the five things I've found that cause the most dead time:
1. The verbal handoff
"Yeah, I told Mike about that car." Mike doesn't remember — he was pulling a transmission. Written workflow tickets that travel with the vehicle eliminate this problem overnight.
2. No visual status board
When you can't see at a glance where every car sits in the workflow, things fall through cracks. Doesn't need to be fancy. Even a whiteboard with columns (Waiting → Diagnosed → Approved → In Progress → Done → Called) changes everything.
3. Approvals sitting in voicemail purgatory
The car's diagnosed, estimate's written, tech is standing there... and the customer hasn't called back. Who owns that follow-up? If nobody does, that car sits. Set a time-based escalation: 2 hours no response → service advisor calls again. 4 hours → call AND text. Make it a written procedure, not a judgment call.
4. Parts delays nobody communicated
Car was promised Wednesday. Part won't arrive until Friday. Nobody told the customer. Now you've got an unhappy customer AND a bay tied up. A simple parts-arrival check at open every morning prevents this entirely.
5. No end-of-day workflow sweep
30 minutes before closing, walk every car in the lot. What's waiting on the customer? What can be staged in a designated waiting area? What's ready to go and needs a final call? This one habit alone cuts average days-in-shop significantly.
If any of this sounds familiar, I put together a free Operations Assessment Checklist that walks through these and a few other common bottlenecks — grab it at gettractionops.com/checklist. No email required, just download and use it.
Curious what systems others here have put in place — especially around the approval/follow-up piece. That one seems to be the biggest variable shop to shop.
      Episode 276 - Navigating Apprenticeships With Shop-Ware Scholarship Winner Kaitlyn Schave
