Trans flush machine?
Looking into buying a machine but am unsure of which to purchase. I don't like the BG bladder type machines because I have watched too many C techs do incomplete flushes because they can't easily see the fluid levels in the machine.
PROS and CONS for your machine please
We currently use the RTI ATX 2 machine. You can easily read the fluid level on the side of the machine. Correct me if I am wrong, but I believe the max capacity is 12qrts. It also comes with the necessary accessories/fittings needed. We've had it for about 4 years with great results.
      Why You Cant Raise Your Price
    • By Hands On
      Hi folks. A quick search and I did not see any recent alignment machine posts. I have a quote from Hunter, $86,000 includes a scissor life and the concrete work to flush mount it, shipping, the machine with wall mount cameras. Some accessories. If I do conservatively 3 alignments a week my break even is approx 4.5 years, a bit longer depending on financing cost.
      I lease my shop, and one of my biggest fears has been getting kicked out of here. Should I be looking at obtaining a location instead? I am always nervous about taking on the massive cost of a bigger building, especially when I struggle so often to hire good people. I talked to a friend that went from a small shop like I have to a larger facility and he said it was a lot more headaches with very little increase in income. I want less headaches, less stress.
      Maybe it is my small shop that makes it hard to hire? Is this the right time to try to get a new location? How do I even start finding financing, I do not have a ton of cash saved up right now. Should I get the alignment machine now, and continue to save up for a new location? How much do I need down for a new spot? Should I keep my eye open for other shops that might fail in the coming year and hold off on the alignment machine and continue to stack cash? I am kind of tired of loosing an employee for 30 minutes to an hour to run an alignment across town that may or may not get done to the same quality standards I hold my employees to.
