Jeep belt misalignment resulting in noise
The 4.0L engines found in the Cherokee and Grand Cherokee have an inherent failure of the harmonic balancer usually at higher mileage and/or vehicles equipped with automatic transmissions; due to leaking transmission cooler line. This “failure” is the result of a separation between the inner and outer sections of the balancer assembly resulting in a clearly visible misalignment and belt noise issue.
  • 5 months later...
Thanks for the tip.
