Has anyone tried the copper/nickel brake lines. I was always under the assumption that brake fluid absorbed copper, in addition to moisture.
Joe,
I hate to say that we have been using it for years, but I never thought about the brake fluid absorbing copper. I will have to find out about that. As far as using it, we have been very happy with it, it bends easily, flairs nicely and resist rusting.
Russ
The Copper Nickle Alloy line has been out for some time now, and it is all I will use at the shop, I don't even stock steel line.
- It does not rust
- It is difficult to kink
- It is easy to bend
- It is easier to cut & flare
It is the one product where there are no negatives, not to mention it is only $4 more a roll through my supplier then traditional steel line.
I have never heard of these lines absorbing brake fluid and I have never had one customer complain about break fluid loss. Copper may absorb brake fluid (?) but this is Copper Nickle Alloy, not a standard copper line.
While on the subject of easy to work with lines, and rust resistant lines, another excellent product that is easy for technicians to work with and will not rust again are the SUR&R nylon/plastic Fuel Line kit. It gives you all the common fuel line fittings (but improved design, easy to disconnect, no more disconnect tools) and the appropriate size line and compression fittings to do nylon patches on steel lines (if only a section is rusted out), or to run complete lines from the tank to the engine.
It saves a lot of time from having to source OE replacement lines, is safer and more professional then high pressure rubber with high pressure fuel clamps, and it will not degrade like rubber over the years, and it will never rust! I will never run metal fuel lines again, and all of my patches are done with this stuff.
I prefer steel lines of coarse, however on the other hand I keep a roll o the copper/nickel on had for those tedious jobs with little space to work. Just like we had to fab alot of line on a car the other day and I was easier to use the c/n.
ATS covered it, all lines are made with copper. The process of rolling the metal into lines is a procedure of wrapping and welding copper and steel and other alloys. Bundy tubes or Bundy pipes, are a type of double-walled low-carbon steel tube manufactured by rolling a copper-coated steel strip through 720 degrees and resistance brazing the overlapped seam in a process called Bundy Welding. It may be zinc- or terne- coated for corrosion protection. It has been used in automotive hydraulic brake lines, for cars manufactured in the USA, since the 1930s.
Interestingly a 1969 study by the SAE recommended the replacement of Bundy tube with 90-10 copper-nickel alloy (UNS C70600 or Kunifer pipe) because of the corrosion concerns. The Kunifer pipe concept has since been adopted by European automakers Volvo, Rolls-Royce, Lotus, Aston-Martin, Porsche and Audi. Bundy pipe retains the advantage higher rigidity, which means less volume expansion under pressure.
As to Joe's concerns, brake fluid does not absorb copper. Rather it simply is a carrier of copper particulate that is abraded off the lines as the fluid deteriorates. The slipping additives and anti corrosives are the first item to break down in the fluid, based on aggressiveness of the driver and age of vehicle. We have no way of telling when the happens so techs must test with our Copper Test Strips ( www.BrakeTestStrip.com ), they instantly ready the Copper concentration in PPM (parts per million). A copper content of 200 ppm or greater indicates a depletion of corrosion inhibitors in the brake fluid, so reach 200 and you need to flush per MAP's UICS procedures.
It is a known fact that brake fluid is designed to protect against corrosion of the system materials it contacts, and that those corrosion inhibitors deplete over time. Additionally, test data shows that this increased presence of copper contamination predetermines the rapid growth of iron contamination and corrosion that has been shown to impede future brake system performance. The valves in ABS pumps just love copper and the platting process that takes place over time is the number one cause of pressure failure.
Hope this information helps, it is critical to replace brake fluid before it looses it protective additives. Please let me know if you need brake strips for testing the fluid, we can offer you a special price since you are members of ASO. Note they we just brought out the newest strip, you can now determine the type of brake fluid in the system, 3, 4, 5, or mixes that must be removed and replaced.
Thanks for this site Joe and the ability to bring tech info all who are members. Please let me know if anyone has additional questions or comments on this subject.
Gary
1(800) 266-4497
Here is a great article about the addition of Copper, Zinc, Nickel and other alloys used over the years...
Worldwide Data On Wear
In 1965, 251,000 automobile accidents in the USA involved brake failures. In that same year, at a major meeting of the Society of Automotive Engineers (SAE), the problem of brake loss due to steel tubing damage was identified as both dangerous and costly. By 1969, the SAE published a study, Hydraulic Brake Line Corrosion: An Initial Investigation of the Problem (A.G. Imgram and D.K. Miner, Paper 690530, Mid-Year Meeting, May 1969). Indications were clear: corrosive deterioration of steel brake tubing created maintenance problems and could be a hazard to safety. The report revealed that steel brake tubing was highly erratic after 4-6 years in service. It also identified copper-nickel alloy C70600 tube as outstandingly superior to conventional steel brake line tubing in laboratory salt-spray-exposure burst tests. Copper and four copper alloys also out-performed the double wrapped steel tubing in the tests.
Sweden, with a national program of vehicle inspection since the mid 1960s, has been a consistent source of the most accurate data on the problem. The Swedes frequently ban vehicles from the road due to badly corroded steel brake tubing. As in the USA, roads in Sweden during the winter are salted for snow and ice removal.
In spite of corrosion-retarding coatings that are applied in accordance with specifications requiring a minimum coating weight per square foot of tubing surface area (not an overall coating thickness), little protection may result in local areas.
Since the 1970s, observed brake tubing faults have diminished with improved coatings. Still, in 1988, over 90,000 Swedish vehicles failed testing due to damaged steel brake tubing, most of which was corrosion related. West Germany, which instituted mandatory vehicle inspections in 1970, has collected data in line with Sweden. Data from the United Kingdom reveal 20% failure rate of brake systems. However, there is no indication of what part of that is attributable to tubing damage.
Fig01.jpgFigure 1. Results of brake tubing inspections of Volvo vehicles with different brake tubing materials.
The Swedish data cover the period during which Volvo upgraded the material it used for brake tubing. Prior to 1971, Volvo had used terne coated steel tubing. In 1971 they changed the coating to zinc. The zinc coating was eventually supplemented by epoxy, and in 1976, Volvo adopted copper-nickel alloy C70600. In Figure 1, the performance of these four materials are compared on the basis of the percentage of observed occurrences of corrosion damage to brake tubing over 12 years of service. Copper-nickel is shown as the most reliable material by far.
Users of copper-nickel brake tubing in addition to Volvo include world-class vehicle manufacturers like Rolls Royce, Lotus, Aston Martin, Porsche and, most recently, Audi. Copper-nickel is also used in military, fire fighting and other heavy vehicles
Ive been asking my local vendors for years to carry test strips! Now I have a source! Thanks for the great info!
Please send me an email or give us a call on the 800 number and I will be glad to help you get some test strips for your shop. They really are the only way to know exactly when to change brake fluid and eliminate any liability on the shops part, they are the only MAP and BAR approved or endorsed test.
We also manufacture test strips for all Radiator fluids, your can check them out at..
Additionally our OE Approved FluidRx program tests fluids in transmissions, power steering units, differentials and motor oil right in your shop and in just 1 to 2 minutes.
Talk to you soon, I look forward to being of assistance.
Gary
P.S. Love NC, we have summer cabin on east side of Asheville up near Warren Wilson College.
We're not that far from there, we're in Blowing Rock.
I'll pm you my email tonight!
Thanks for such a great article!
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Carm Capriotto sits down with Todd Fortier, retiring automotive professor and program coordinator from Illinois Central College, to discuss a lesson learned over three decades in education: anyone can teach, but becoming a true educator requires purpose, empathy, and continuous growth.
      Todd shares how his passion for education was sparked by helping students experience those breakthrough "lightbulb moments" and why the ultimate goal of teaching is not simply delivering information, but ensuring meaningful knowledge transfer. As he prepares for retirement, Todd reflects on the challenges facing automotive education and his mission to help develop the next generation of industry instructors.
      What You'll Learn Why technical expertise alone doesn't make someone an effective instructor How educators can improve knowledge transfer and student engagement Todd's "Three C's" framework: Concern, Cause, and Correction Why connection, empathy, and vulnerability are critical teaching tools How to identify the root causes behind student disengagement The importance of recognizing the personal challenges students bring into the classroom Why many students leave training programs early and how educators can help retain them How trainers and mentors can evolve into true educators The soft skills needed to successfully connect with today's students and technicians
      The best educators do more than share information, they build relationships. Todd Fortier's career demonstrates that teaching is most effective when instructors combine technical knowledge with empathy, curiosity, and genuine human connection. As the automotive industry works to address technician shortages and workforce development challenges, creating better educators may be one of the most important investments the industry can make. Todd Fortier, Professor/Program Coordinator, Illinois Central College, [email protected] Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/
      Visit the Website:https://remarkableresults.biz/ Subscribe on YouTube:https://www.youtube.com/carmcapriotto Follow on Facebook:https://www.facebook.com/RemarkableResultsRadioPodcast/ Follow on LinkedIn:https://www.linkedin.com/in/carmcapriotto/ Follow on Instagram:https://www.instagram.com/remarkableresultsradiopodcast/ Join Our Virtual Toastmasters Club:https://remarkableresults.biz/toastmasters Join Our Private Facebook Community:https://www.facebook.com/groups/1734687266778976 Join our Insider List:https://remarkableresults.biz/insider All books mentioned on our podcasts:https://remarkableresults.biz/books Our Classroom page for personal or team learning:https://remarkableresults.biz/classroom Special episode collections:https://remarkableresults.biz/collections Buy Me a Coffee:https://www.buymeacoffee.com/carm
      The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ Remarkable Results Radio Podcastwith Carm Capriotto:Facilitating Wisdom Through Story Telling and Open Discussion.https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z:From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life.https://mattfanslow.captivate.fm/ Business by the Numbers: Understand the Numbers of Your Business with CPA Hunt Demarest.https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level.https://autorepairmarketing.captivate.fm/ The Weekly Blitz: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching.https://chriscotton.captivate.fm/ Speak Up! Effective Communication: Develop Interpersonal and Professional Communication Skills with Craig O'Neill.https://craigoneill.captivate.fm
    • By HeneryH
      I know this sounds like spam but hear me out.  I am a software nerd who had a few weeks of downtime recovering from a surgery.  I used that downtime to learn about how AI can be used to create applications.  The test scenario I used was an auto mechanic shop that had to manage 5 service bays.  I got the idea from my local mechanic who uses one of those physical desktop paper calendar planners.  He pencils in appointments literally on the paper calendar.
      My goal was primarily to learn about how AI can generate the apps.  That is done.
      Now I have this app that is kind of done.  I am not in the business of selling apps.  I have no interest in that.
      I am posting here because it would be a shame to throw it away.
      I will post the application that the AI helped me generate as an open source software that is completely free to use.
      If you would like to participate in helping with the business logic (I am only guessing as to how shops operate) then I can make any updates that you all suggest.  I can probably host about five shops on my home server if you want a clone instance of the app for your shop.  Or you can take the code and run it for free on your own computer. I can help you do that.
      I am doing a little more polishing tonight and will post links and screenshots for anyone who wants to try it out.  Assuming this thread is not deleted by the mods.
      I'm not selling, just want the small personal satisfaction of someone actually using it if they like it.
      This is the prompt I gave to the Claude AI system:
      Claude generated a system that was about 90% of the way there but it also helped me fix the remaining 10%.  As a sw nerd it it really amazing.   I would have taken a week or two to do this but with Claude it took me a day.
      Here is the link to the demo system:  https://demo.flynnconsultingllc.com/
      There are three personas that the system uses:
      * Manager of the whole shop who assigns scheduled cars to bays
      * Bay Lead who manages the bay o bays in his control, bringing queued cars into active and statusing them
      * Customers who can schedule service for their cars
    • By Drivi
      Every shop I’ve worked with seems to have the same pattern — two crazy weeks where everyone’s buried, then a week of half-empty bays and techs sweeping the floor.
      I’m trying to understand how other shop owners manage that cycle. Do you:
      Schedule preventive maintenance in advance?
      Use software to predict when customers are due for service?
      Just let the phone ring and deal with the chaos?
      I’m currently testing an AI-based tool that tries to predict upcoming maintenance needs for each customer, basically helping balance the workload week to week.
      Not looking to pitch anything — I’m more curious if anyone here has already built a system that works for them.
      Would love to hear what’s actually working (or not) in the real world.
      If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," Coach Chris Cotton takes the stage to unveil an exciting new series titled "Back to Basics," specifically designed for auto repair shop owners and their teams. This series is crafted to revisit and reinforce the essential concepts and practices that are crucial for running a successful auto repair shop. Coach Chris passionately emphasizes the significance of having a solid grasp of the basics, particularly in the face of financial challenges and the myriad distractions that can arise in the industry.
      He meticulously outlines a comprehensive ten-part series that will delve into a variety of critical topics. These include effective communication strategies, robust financial management techniques, and the cultivation of strong teamwork within the shop environment. Each segment is designed to equip shop owners and their teams with the foundational knowledge and skills necessary to thrive in a competitive market.
      Moreover, the episode underscores the importance of continuous learning and development in the ever-evolving automotive repair industry. Coach Chris encourages listeners to embrace ongoing education as a means to stay ahead of the curve and maintain a competitive edge.
      In addition to the valuable insights shared, the episode features a sponsorship mention for Shop Marketing Pros. This marketing company specializes in helping auto repair shops grow by providing tailored marketing solutions that drive business success. Their expertise and support are highlighted as a valuable resource for shop owners looking to expand their reach and enhance their market presence.
      ​Introduction and Podcast Overview (00:00:07)
      Coach Chris introduces the podcast and its purpose to supercharge auto repair businesses.
      Sponsorship Mention (00:01:17)
      Discussion of Shop Marketing Pros and their services for auto repair shops.
      Episode Series Introduction (00:01:17)
      Introduction to the "Back to Basics" series focusing on fundamental concepts in auto repair.
      Importance of Fundamentals (00:02:16)
      Highlighting the need to revisit basics due to challenges faced by shop owners.
      Gaps in Shop Foundations (00:03:27)
      Discussing the distractions that lead to gaps in business fundamentals post-COVID.
      Overview of the Series Topics (00:04:25)
      Preview of the ten episodes covering essential topics for shop owners and technicians.
      Target Audience for the Series (00:06:31)
      Identifying the audience: shop owners, service advisors, and technicians.
      Encouragement for Team Participation (00:06:31)
      Encouraging teams to listen together and discuss improvements based on the series.
      Conclusion and Final Thoughts (00:07:27)
      Reiterating the importance of foundational knowledge and promoting the series for shop success.
      940-400-1008
      YouTube: https://bit.ly/3ClX0ae
      Email Chris: [email protected]
