I'm inclined to think it may still be a mount issue. Where did the replacement mount come from? If one was broken chances are the others are not at full capacity either. I haven't worked on this line of cars for a while now, but the last few I did, I recommended replacement of all three because they were actually worn. Try placing a 2x4 on a jack and slightly raise the engine with it in drive to see if the vibration disappears. I couldn't imagine a flush causing a vibration issue, maybe that is just when they decided to notice it.
A first time customer, referred to us by another customer, brought her 2003 Honda V6 Accord to us for a vibration problem felt through the steering wheel only at idle, in drive, with the car stopped. The vibration is more prominent when she begins to turn the steering wheel. The vibration is slight, but it’s there.
We did find a broken engine mount and replaced it. The customer says it’s “slightly” better, but the problem is not solved. We have gone thru the car with a fine tooth comb and found nothing else wrong. The car only has 50k on the clock and is in pristine condition and well maintained (I saw her records).
She said the problem started a year ago when the Dealer did a Power Steering flush and Transmission flush.
Does anyone have any ideas or help? Has anyone seen any issues with a vibration in the steering wheel after a Power Steering flush service was performed? Any help would be greatly appreciated.
Did you use O/E mount - Yes all should be replaced thier is actually three plus I believe stablizer shock . The aftermarkets sloves the broken but not vibration.
Did you use Factory mount / Also I belive thier is three mounts plus one or two Stabilizer shock . We ran into the same issue with aftermarket mounts / cured sagged and broken but not vibration.
Thanks Dan R.
Several bullentins on this car for vibrations
  • 2 years later...
Could be a tie rod, either inner or outer. Have you tried an alignment? I am sure one of those three places has at least checked it?? I would think at least. Try this one time, jack up one of the front wheels using the lower control arm just enough for you to comfortably get you hand under it, say maybe 3 or 4 inches? And i say by the control arm because you want to keep the suspension under load or mimic it sitting on the ground. Grab the wheel at 3 and 9 o'clock and quickly turn the wheel back and forth. But only a wiggle and somewhat gentle see if you notice any play or looseness. If you do then its one of the tie rods on that side. Do the same thing at 6 and 12 o'clock and see if there is any play in the ball joints. And both again on the other front wheel (front only). Beyond that you might be looking at a power steering or suspension issue.
Atif Naser
I have hot rodded a lot of power steering pumps to add hyralic rams to 4x4 steering. If the bypass valve in the pump is opening and closing I can see a vibration. Have you run the motor without the belt to verify her concern? Right fluid in the pump?
Have you attempted to compare this vehicle to another vehicle of the same likeness? Sometimes, after a customer opts to move forward with a service, they approach the vehicle with a heightened state of awareness regarding the system serviced. Is it possible that this condition was always present and is inherent to the vehicle? In your professional opinion, does this vehicle have a legitimate condition/abnormality.
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Watch Full Video Episode Host Carm Capriotto speaks with Jay Goninen, co-founder and president of WrenchWay, about insights from the 2026 Voice of the Technician Survey and what it reveals about the state of the automotive workforce.
      Jay encourages shop owners to download the free report to uncover blind spots and start meaningful conversations with their teams. The data show that technicians strongly prefer a four-day, 10-hour workweek with no weekends, along with proper equipment, paid vacation, retirement benefits, and paid training.
      While dealership technicians made up a larger share of respondents, independents stood out in workplace culture. 63% of independent technicians would recommend their shop to a friend, compared to 36% at dealerships, though dealerships scored higher in providing paid training. Across both groups, technicians favor an hourly wage plus bonus structure, which many feel better supports diagnosticians than traditional flat-rate systems.
      The discussion also highlights a troubling trend: the industry’s Net Promoter Score dropped to -60 in 2026, signaling that many technicians would not recommend the profession to others.
      To strengthen the talent pipeline, Jay discusses ASE Connects, a new initiative aimed at connecting shops with high school and technical school automotive programs to support them through mentorship, advisory roles, and community engagement.
      Carm also advocates elevating the profession by shifting the language from “mechanic” or “technician” to “specialist,” emphasizing the expertise required to work on today’s vehicles.
      Overall, the episode serves as a wake-up call for shop owners to use the survey insights to evaluate their culture, communication, and work environments, and to become employers technicians are proud to recommend.
      https://wrenchway.com/resources/2026-voice-of-technician-survey-report/
      Jay Goninen, Co-Founder and President, WrenchWay
      Thanks to our Partners, NAPA Auto Care and NAPA TRACS Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Connect with the Podcast: - Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ - Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters - Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 - Subscribe on YouTube: https://www.youtube.com/carmcapriotto - Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ - Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ - Visit the Website: https://remarkableresults.biz/ - Join our Insider List: https://remarkableresults.biz/insider - All books mentioned on our podcasts: https://remarkableresults.biz/books - Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom - Buy Me a Coffee: https://www.buymeacoffee.com/carm - Special episode collections: https://remarkableresults.biz/collections - The Automotive Repair Podcast Network: https://automotiverepairpodcastnetwork.com/ - Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ - Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ - Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ - The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ - The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ - Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm                         Click to go to the Podcast on Remarkable Results Radio
