smoke machine
I have an older snapon smoke machine I got a good used deal on from the snapon truck. Has to blow smoke out a hose. Got mine a year ago and can't believe how often I use it. Intake leaks, exhaust leaks, gas tank leaks on small engine tanks. And of course, evaporated leaks. Could never go back to not having one.
Sent from my SM-N920V using Tapatalk
Re: Smoke machines. We make a lotta money with our smoke machine. I don't remember what brand it is, because to me they're all the same. They make smoke and it flows into the system you're checking, and wherever it comes out is where you put the fix!!
When a car comes in with the "service engine" light on, and we read an evap leak, we explain that we need to hook up the smoke machine to the car, and it's $89.95 to smoke it.
Cha-Ching$$
Hi-Gear
For the record is difficult to accurately diagnose evap codes without it. The other uses like lean codes, wind inside the car all are super useful. Had a 1995 Buick with lean codes. Thought since it was old it was gna be easy to check for vac leaks.... Car spray the hoses. We'll after chasing my tail I put the smoke machine to use. 3 tiny hoses were cracked.... Fixed in 5 minutes once bought some more hose. In conclusion, this isn't just for new cars, it's for anybody who is SERIOUS about diagnostic and accuracy!
I have the cheaper snapon, it was $1300 or so. Before that I had a DIY machine for about 2 years. Before that I would fill the evap systems with 1.5psi of air and use soapy water to find leaks. Both worked, but the snapon is much easier.
Whatever smoke machine you get I would suggest you charge a separate fee for that test alone or package it together with a series of tests. For instance we package a smoke test into our level 1 diag which comes out to $150 before tax and fees. We used to charge $99-119 alone for a smoke test but we have since developed a tiered system for our diag process which makes us more profitable, streamlines the process, and has much more detailed explanation of all the tests and procedures we are doing which equates to value for our clients.
We have both an OTC smoke machine (which I'd like to upgrade) for our regular smoke tests and also a high PSI smoke machine by redline for boost leaks.
Edited by mspecperformance
A little off topic but how do you structure your diagnostic tiers? I need to find a better way to bill diagnostic time, especially a way to give the customer an idea of what they are in for before the job starts. Currently we bill most diagnostic fees hourly and tell the customer they should be prepared for at least an hour of time. I'm sure there is a better way though.
As for a smoke machine, get one, who cars what brand. I can't imagine getting by without one. We have an OTC and it gets used nearly every day. To be safe you should get a nitrogen generator or a smoke machine that has one built in. Its technically dangerous to pump a fuel tank full of compressed air. Most modern cars have pump modules so the pump is never exposed to air but if you try it on something old there is a chance for explosion if you're not using nitrogen. I use the machine to find intake air leaks on metered air systems. Probably the #1 cause of fuel trims being long.
Agree with Redline. Yes, we fix cars & make a ton of money with it. Use it almost every day.
Start at 1.0 labor charge for smoke test plus for the initial code check then go from there for repairs.
Dave
Hello Everyone,
If you are able to buy any sort of smoke machine, you are lucky because most people use a cigarette or anything to produce smoke. If you do have the extra hundred bucks to spend than you can find great deals on craigslist or any classified website. My smoke machine is simple and does the job to catch for emission leaks. Most cars have an area were you can connect the hose. In most cases it's located under the hood and covered with a green top screwed on.
Good Luck!
Erik Gonzalez
EEE Auto Repair in Tracy
24/7 Roadside Assistance & Towing in Tracy
      Thanks to our Partner, NAPA Auto Care Recorded Live at Vision Hi-Tech Training & Expo, Jeremy O'Neal shares his journey of transforming a struggling business into a thriving enterprise, emphasizing the critical role of service advisor training.  Jeremy also highlighted how understanding the business, the owner's goals, and team dynamics is essential before implementing any training program. It's not just about fixing cars; it's about creating an exceptional customer experience that drives business success. Jeremy O’Neal, Advisorfix, Freedom Auto Repair, Hesperia, CA. Previous episodes HERE. Show Notes
      Service Advisor Coaching & Training: https://www.advisorfix.com/ Jeremy's Transition to Shop Ownership (00:00:36) Jeremy discusses his transition from service advisor training to owning Freedom Automotive. The Impact of Vision 2024 (00:04:17) Jeremy and Carm discuss the impact of the Vision 2024 event on their lives and the industry. Youth Presence at Vision 2024 (00:04:48) Carm and Jeremy discuss the significant presence of young talent at the Vision 2024 event. Jeremy's Business Growth (00:06:56) Carm inquires about the growth of Jeremy's business over the past eight years. The Importance of Service Advisor Training (00:07:11) Carm and Jeremy discuss the critical need for service advisor training in the automotive industry. Jeremy's Business Transformation (00:08:55) Jeremy shares the transformation of his shop, including significant growth and plans for expansion. The Role of Service Advisors in Business Growth (00:09:29) Jeremy discusses the potential for business growth by adding service advisors and technicians. Customer Service Challenges (00:10:45) Jeremy and Carm discuss the decline in customer service and the impact on the automotive industry. The Role of Customer Experience (00:12:21) Carm emphasizes the importance of creating a great customer experience in automotive repair shops. Parenting and Cultural Observations (00:13:24) Jeremy shares his observations and concerns about modern parenting and societal changes. Firing underperforming staff (00:15:20) Jeremy discusses his commitment to high service standards and the consequences for those who don't meet them. Training and standards (00:16:07) Carm questions Jeremy about his work-life balance and the importance of training in maintaining high standards. NAPA Auto Care Center program (00:16:55) Carm discusses the benefits of the NAPA brand and the Pro Image upgrade program for automotive shops. Employee commitment and performance (00:19:00) Jeremy shares his experiences with committed but underperforming employees and the impact on customer service. Service advisor training and culture (00:21:20) Jeremy emphasizes the importance of daily coaching and the shop owner's role in guiding training and culture. Continuous improvement and learning culture (00:23:03) Jeremy discusses the importance of employees having a learning culture and the availability of educational content. Phone call analysis and customer service (00:24:22) Jeremy explains the value of listening to service advisor calls for assessing competency and customer responses. Service advisor's impact on top-line sales (00:26:26) Jeremy highlights the significant impact of service advisor competency on the shop's top-line sales. Life Cycles with Customers (00:30:57) Jeremy shares a personal anecdote about a customer's car and the importance of understanding customer needs. Building Trust with Customers (00:31:35) Jeremy discusses the importance of building trust with customers and ensuring they follow the shop's process for repairs. Market Trends and Automotive Industry (00:32:52) Jeremy talks about market trends, the impact of COVID-19, and the future of the automotive industry, including the rise of EVs and hybrid vehicles. Success in the Marketplace (00:34:19) The discussion revolves around the importance of solid processes, good people, and effective marketing to succeed in the marketplace. Communication and Networking (00:35:18) The conversation shifts to the significance of communication and networking, including a mention of the Disney Institute's emphasis on personal interaction. Reflecting on Life's Milestones (00:37:21) Jeremy reflects on life beyond 50, the legacy he aims to leave, and the importance of capturing special moments with loved ones.
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections
    • By Hands On
      Hi folks. A quick search and I did not see any recent alignment machine posts. I have a quote from Hunter, $86,000 includes a scissor life and the concrete work to flush mount it, shipping, the machine with wall mount cameras. Some accessories. If I do conservatively 3 alignments a week my break even is approx 4.5 years, a bit longer depending on financing cost.
      I lease my shop, and one of my biggest fears has been getting kicked out of here. Should I be looking at obtaining a location instead? I am always nervous about taking on the massive cost of a bigger building, especially when I struggle so often to hire good people. I talked to a friend that went from a small shop like I have to a larger facility and he said it was a lot more headaches with very little increase in income. I want less headaches, less stress.
      Maybe it is my small shop that makes it hard to hire? Is this the right time to try to get a new location? How do I even start finding financing, I do not have a ton of cash saved up right now. Should I get the alignment machine now, and continue to save up for a new location? How much do I need down for a new spot? Should I keep my eye open for other shops that might fail in the coming year and hold off on the alignment machine and continue to stack cash? I am kind of tired of loosing an employee for 30 minutes to an hour to run an alignment across town that may or may not get done to the same quality standards I hold my employees to.
